My Senior design project - a "Swamp Thing" tracked vehicle clone
   / My Senior design project - a "Swamp Thing" tracked vehicle clone
Thanks for the kudos.
...I wonder about the weight.
-> In what way? Also, what's a "headache rack"? I have been pondering my options around and above the engine bay. At this time, I plan to install a pair of removable storage boxes that will be the same height of the engine hood. A removable frame will set on top of everything that could be used to lash down cargo. After I clean up the design some more, I will post an image for comment.
   / My Senior design project - a "Swamp Thing" tracked vehicle clone #222
Thanks for the kudos. -> In what way? Also, what's a "headache rack"? I have been pondering my options around and above the engine bay. At this time, I plan to install a pair of removable storage boxes that will be the same height of the engine hood. A removable frame will set on top of everything that could be used to lash down cargo. After I clean up the design some more, I will post an image for comment.
Headache rack is basicly the same thing as a roll bar. Usually used on work trucks and has mesh to protect the cab Screenshot_20191115-090729_Google.jpeg
   / My Senior design project - a "Swamp Thing" tracked vehicle clone #223
   / My Senior design project - a "Swamp Thing" tracked vehicle clone #225
It prevents a headache when an improperly secured load comes through your rear window. Or it gives you a headache when that happens (as opposed to no longer having a head to hurt or not).
   / My Senior design project - a "Swamp Thing" tracked vehicle clone #226
   / My Senior design project - a "Swamp Thing" tracked vehicle clone #228
I have no vehicle goal or use in mind except to possibly be able to get to the store in a blizzard if I (or the wife) run out of beer (for me) or wine. I guess a goal might be to have it drive around the yard successfully without throwing a track. It appears the vehicle weight may end up in the vicinity of 1700 lbs. Since the design is in cad, I may, in the future, sell build-your-own drawing packages on EBay to ... buy more beer. :drink:
Actually, I have a working under-utilized 20 hp twin Onan engine in the shed that I was thinking, might be able to power a snowblower attachment on Snowzer.
IRTPL 10,000 LBS TWO POST LIFT (A58214)
IRTPL 10,000 LBS...
2024 MACK GRANITE GR46F DUMP TRUCK (A59823)
2024 MACK GRANITE...
Pull Type ATV Sprayer (A59814)
Pull Type ATV...
2014 Chevrolet Express Van (A55973)
2014 Chevrolet...
2015 DODGE DURANGO RT SUV (A59575)
2015 DODGE DURANGO...
17101 (A55851)
17101 (A55851)
