My Senior design project - a "Swamp Thing" tracked vehicle clone
   / My Senior design project - a "Swamp Thing" tracked vehicle clone
Thanks for the kudos.
...I wonder about the weight.
-> In what way? Also, what's a "headache rack"? I have been pondering my options around and above the engine bay. At this time, I plan to install a pair of removable storage boxes that will be the same height of the engine hood. A removable frame will set on top of everything that could be used to lash down cargo. After I clean up the design some more, I will post an image for comment.
   / My Senior design project - a "Swamp Thing" tracked vehicle clone #222
Thanks for the kudos. -> In what way? Also, what's a "headache rack"? I have been pondering my options around and above the engine bay. At this time, I plan to install a pair of removable storage boxes that will be the same height of the engine hood. A removable frame will set on top of everything that could be used to lash down cargo. After I clean up the design some more, I will post an image for comment.
Headache rack is basicly the same thing as a roll bar. Usually used on work trucks and has mesh to protect the cab Screenshot_20191115-090729_Google.jpeg
   / My Senior design project - a "Swamp Thing" tracked vehicle clone #223
   / My Senior design project - a "Swamp Thing" tracked vehicle clone #225
It prevents a headache when an improperly secured load comes through your rear window. Or it gives you a headache when that happens (as opposed to no longer having a head to hurt or not).
   / My Senior design project - a "Swamp Thing" tracked vehicle clone #226
   / My Senior design project - a "Swamp Thing" tracked vehicle clone #228
I have no vehicle goal or use in mind except to possibly be able to get to the store in a blizzard if I (or the wife) run out of beer (for me) or wine. I guess a goal might be to have it drive around the yard successfully without throwing a track. It appears the vehicle weight may end up in the vicinity of 1700 lbs. Since the design is in cad, I may, in the future, sell build-your-own drawing packages on EBay to ... buy more beer. :drink:
Actually, I have a working under-utilized 20 hp twin Onan engine in the shed that I was thinking, might be able to power a snowblower attachment on Snowzer.
2018 ASV Posi-Track RT120F (A47477)
2018 ASV...
2019 CATERPILLAR 259D SKID STEER (A52705)
2019 CATERPILLAR...
Wacker WM90 Jumping Jack (A50775)
Wacker WM90...
Chop Saw and Max 43 Plasma Cutter (A54865)
Chop Saw and Max...
2008 Chevrolet Silverado 4x4 Crew Cab Pickup Truck (A55852)
2008 Chevrolet...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A55302)
2023 New Holland...
