My NX6010
/ My NX6010 #1,202
100hrs is roughly equal to 3000 miles His tractor has 9,000 miles.
How do you figure that? An engine running at typical 2000-2200rpm in an auto would cruise at about 60mph. 300 hrs at 60 mph would equate to 18,000 miles.
/ My NX6010 #1,203
I am going from what I have seen on vehicles that have an hour meter.
I guess there other ways of looking at it. You could say a car will last 300k miles and a CUT will last 6,000 hours so that would be an average of 50MPH.
Tractors and cars are used differently so it is tough to do a direct comparison. Something that may never wear out on a tractor may wear out on a car and vice versa.
Here is some reading on the subject:
Hours vs. Miles???
http://www.tractorbynet.com/forums/owning-operating/17367-covert-tractor-hours-miles.html
http://www.tractorbynet.com/forums/buying-pricing-comparisons/203084-hours-vs-miles.html
http://www.tractorbynet.com/forums/owning-operating/192284-operating-hours.html
/ My NX6010 #1,204
The service interval on my Workmaster is 300 hours. I think some larger AG tractors use 600 hours. I'll average around 80 to 100 hours a year so I'll be servicing annually. I always figured 300 hours as 15K miles at 50 MPH average. Hard to break old habits of less frequent oil changes.
/ My NX6010 #1,205
My Comanche and Mooney aircraft I changed the oil every 25 - 30 hours, but that was a half dozen round trips to Florida.
/ My NX6010 #1,206
Most cars average between 25 and 45 MPH over their lifespan. (depending on how much city vs highway miles they have) My wife's 2005 Yukon has about 130k miles and around 3700 hours on the engine.
Aaron Z
/ My NX6010 #1,207
Hello ALL. Newer member reading everything and learning. An amazing group of regulars here with extreme knowledge. THANK YOU. I just purchased delivered today 2106 NX 4510 HST Cab with backhoe, 2 rear remotes. Also from EA wicked grapple, rear scraper, hd box blade and pallet forks. Have MIE hydraulic thumb on hoe and WR Long 3 rd function. AG tires. I am considered to be pretty good mechanically but am so DUMB in understanding electronics and hydraulics but learning hydraulics quickly. I have 3.1 hrs and mine shifts Hard into M gear.
I will post pics of all very soon.
Eric you are a guru and what you have been able to do with tractor is amazing. Tractors are made for working an I don't think you have abused your machine but it sure does take a lot of money to repair and know how.
I purchased my Kioti like others research research research led to my decision as best ROI.
I bought specifically for the next 3 big projects.
20x28 addition to house doing my own site prep and building.
36x56 garage shop ploe barn heated and insulated.
Build pond dam across 3 sided ravine with a natural spring 140 ft long 15 ft high 140 ft wide. Getting clay no problem have 36000 cu yds 120 ft away.
First need to clear ravine of some trees and 25 yrs of neglect.
I will need a 1 to 2 yd pull behind dirt scraper and fully know it will take about 500 hrs.
Then move 3000 cu yds dirt to fill in slopes around house area.
I only have about 4 acres of low sloping areas for pastures etc. the other 16 acres are 20 to 40% grade hills. Some can be reworked most cant without dozer and that is prohibitively expensive.
The ideas and cures you guys do will help me very much as I make guards, etc.
I will ask for specific help when I want to add TNT and side lift cylinder and anything electric.
But right now when Eric mentioned jumping connection to trick the safety seat switch = HOW specifically.
Thank you ALL.
Dan
/ My NX6010 #1,208
You can unplug the connector under the seat and install a shot jumper wire. Some guys have even installed a switch inline so they can keep the seat switch operational but if for some reason need to bypass the seat for a time they simply flip the switch and when finished flip it back to normal. On my nx5510 I just removed the two shoulder bolts with springs that held the front of the seat cushion on, and replaced with short full threaded bolts which hold the cushion down keeping the switch bypassed.
/ My NX6010 #1,209
Thank you, I did read that and the bolts didn't hurt or interfere with seat or you?
Thanks. I do like the switch idea like when the kids and grandson visit.
/ My NX6010 #1,211
No the bolts dont cause any issues. The bypass switch may be a better option for you if you have operators with little to no experience on the machine.
/ My NX6010 #1,212
I have a thread with pictures, NX safety switch mod.
Not sure how to link to it...
Go to the thread that you wish to post a link to. Then highlight the URL in the browser address window, then right click on the highlighted text and when the dropdown box appears click on copy. This places the URL (address) on your "clipboard". Now come back to this thread and open a reply and just right click in the box and press paste. Post and your done.
/ My NX6010
I haven't had a chance to set-up or use my latest attachment yet, but I promised Everything Attachments that there will be video raking beaches, leveling ground, and raking junk of every kind imaginable. I think this was the first one EA made.
/ My NX6010 #1,216
Hello Eric, and a salute to all the forum users.
I joined in order to get information about the Kioti tractors, nx6010 in particular.
I have a winery in Friuli (Italy) 20 hectares and use different tractors Massey fergunson and new holland, all too heavy machines to be used during treatments in the vineyards, because most 'rains the greater the number of treatments that I have to perform, the greater the damage that i go on the wet turf with my tractors, which have a greater weight of 3 tons.
The Kioti only weighs 2 tons, it can 'be equipped with low-pressure wheels for gardening! A great solution for my problems.
I have a number of doubts about the mode of operation of the tractor Kioti that I would like to clarify with the 'help of Eric, if available to answer my questions.
In Italy the Kioti is very little spread among farmers, while it is utilizzto by gardeners and municipalities for the management of the green, then with different operational needs from mine.
For some months now we import the model nx6010 Kioti and representatives have made me some good proposals with very good price, but know little about the car and so I wanted some clarification on who uses it first to 'purchase to proceed.
Thank you.
I know just the 'English to write properly and use google to translate!
/ My NX6010 #1,217
Thank you.
View attachment 476336View attachment 476337
My kioti is a little bigger, but I use it in my orchard. I think the the NX6010 would do very well for your vineyard. Your sprayer might be limited. You will have 48 HP at the PTO.
/ My NX6010 #1,218
Thanks for the clarification.
My nebulizer has a fan of 70 cm and should need about 30-35 hp.
My doubt is on the functioning of Kioti at work , namely:
1- ok to fix the number of the engine speed via the cruise control , in order to have the operation of the nebulizer at 520-540 r / min .
2- the same way you can set a constant speed of 6.5 km / h through the cruise control ?
3- where I see on the dashboard of Kioti speed pto and how many km / h I'm running ?
4- all ' beginning of the rows , to turn the means , I have to decrease the speed , but then there is a way to reset it as decided to ' start of treatment ( that is, I can get back to running at 6.5 km / h ??) .
Thank you for the info!
/ My NX6010 #1,219
In Europe, you can buy manual transmission NX6010. In the US it is only available with HST. I see UK spec sheet lists "true speed cruise control". I would go test drive one. Tell them what you'd and see if they can do it.
/ My NX6010 #1,220
Today I wrote your local Representative . The way to exist to "fix " via the cruise control in both number of revolutions of the engine , both the speed .
When I arrive at the end of the row can exit the cruise control by tapping the brakes or pedals forward / reverse . Once placed on the row Toggle Next I reset the speed with the cruise control button.
He also told me that the dashboard does not display the revolutions of pto , their speed . But it has a sensor to use the speed reading through a third-party counts kilometers .
One more info that I have not found . What is the maximum speed in first gear ? in the second range ? the third range ( this last is easy , from 0 km / h to 30 Km / h !! ) .
Another problem in Italy the maximum permissible towing the cart is only 3 tons !!! In Germany however it is 5 tons . Usual EU rules incomprehensible .
In you are interested in hst version, not the one on the manual gearbox !
UNUSED 1RANCH 1RET13 ELECTRIC TRICYCLE (A64280)
UNUSED 1RANCH...
2001 Kubota L3300F 35HP Utility Tractor with Caroni TC710 6ft. Rotary Brush Mower Attachment (A59228)
2001 Kubota L3300F...
Trail King Trailers Parts Books Vol. 1 and Vol. 2 (A63117)
Trail King...
2007 Generac 0054200 Quiet Source 35kW Natural Gas Generator (A61572)
2007 Generac...
Caterpillar Service Manual Reference Kit for Motor Graders, Wheel Type Tractors, and Equipment (A63117)
Caterpillar...
2014 Bobcat T650 (A60462)
2014 Bobcat T650...
