murphy1244
Super Star Member
- Joined
- Nov 25, 2011
- Messages
- 19,522
- Location
- Ohio
- Tractor
- Kubota 1120 RTV Kioti DK-40, MF-135, Ventrac 4500Y
Who's backhoe was this?
A lot of manufactures have this problem. VW, the company that sells the most turbo charged engines have this same problem too. It is easily solved with a water/air inter cooler than the air/air inter cooler. VW has has plenty of TDI's hydro lock. The new VW engines all have the water/air inter cooler.
I googled the model number.
That said, get an excavator as they are way more efficient than backhoes.
Dozer. That said, get a Dozer. Way more efficient than a Tractor.
To the best of my knowledge, the only aftermarket intercoolers are air to air. One does have a water vent, but that doesn't solve the problem of eliminating the pressure drop in the first place that condenses out the water from the intake charge. However, I did just ask an engine forum if anybody knew of a specific 3.5L water to air application. Be nice if somebody did because it would all but eliminate the water charging problem due to the near nothing pressure drop water to air intercoolers tend to enjoy.
How much water and oil came out of your intercooler? When I have taken the intercooler out of the 6.4 diesels it is amazing how much water and oil runs out of some of them.
What shipping company shipped the roof for your tractor? This summer I ordered a gas tank for my 69 chevy truck and after the third damaged one thanks to UPS I decided to have the original one repaired. I was told certain depots are known for damaging products, so that was when I decided to get mine repaired.
I need to get a tilting ram for NX with check valves but I'm having problems finding anybody who sells them.
I bought TNT cylinders without the check valves for my DK45SE. Double whammy there - first, the rear remotes have no float position; and second, the valves do leak down fairly quickly. I have to raise my tilt cylinder about every 15 minutes to prevent the right front corner of my brush cutter from digging in. I vote for the check valves for your application.
Based on this thread, I thought about talking Eric into one of these: High Horsepower Grader Clearing Box Blade
Travis
