My mini dozer build
/ My mini dozer build #41
I;ma watchin..........
What are these parts for?? Will you be adding actuators for the blade?
Sorry about the poor posting. It's easier for me to build this stuff than to post it. The top 2 pictures show the back side of the blade. The center plate is what will attach to my A frame and has the provision for sideways tilt and left and right angling. And yes it will be controlled by hyd.cylinders. I'll try to get more pictures soon.
Inside of blade before closing with front skin
Front of blade clamped in preparing to weld.
Rear view after welding
Front and end view after welding.
I'm starting to wonder if I've over built a little?
I've sat behind the old dozers for quite a few thousand hours clearing land in my younger years and they do take a real beating!
I've got a 4 in.wide strip of T1 to weld on for a cutting edge yet to.
/ My mini dozer build #44
Here one my brother worked on one for a guy. Terrible drive system with belts and chains. Believe it was built in the early 60's from a kit. Was in Popular Mechanics magazine.
/ My mini dozer build #45
Awesome fab skills. Keep an eye on the 4 bolt flange bearings. We use a lot of em at work. When our operators are loading and unloading rolls if they bump into the the shafts supported by the bearings they have a tendency to crack the housings.
Ok I will. Quite a few unknowns yet. Will find out more when I put it to work😃
I think I'd have gone with a simple pin and dom pipe for this joint. Of course with a grease zek. :unsure:
I think you are right I probably over thought that one. Won't be real hard to change if it fails.
/ My mini dozer build #51
Here is my latest project. Spent most of a year at it. Has been very satisfying. Engine is 3 cyl. Kubota 20 hp. Drive is fully hydrostatic from a wrecked Massey swather I had given to me. Drive motors are 29 cu.in orbit motors from Princess auto. Brand new mini excavator tracks the single largest expense in the project. Didn't keep track of total time or expense but must be 1500 hrs and 5 or 6 thousand dollars by now. Any parts that could possibly be plasma cut I did on my 4x8 ft. Cnc plasma table including front idlers, rear drive sprockets and track rollers. Total weight might be 1200 lbs. Just guessing though. Top speed is close to 5 mph. Planning a 6 way dozer for it yet to. I'm very new at posting this kind of a thing so please bear with me.View attachment 692193View attachment 692194View attachment 692195View attachment 692197
Absolutely toooo cool. I know it is an effort to post the pic's and answer the questions, but, please keep it up:)
Best,
ed
Hydraulic plumbing turned into a plumber's nightmare. Just ran out of room for everything20210511_203804.jpg
Sorry for all the confusion of posting!
I've put on probably 12 to 15 hours now doing various dozer projects with quite a few trips back to the shop for warranty work. Over all I'm more than happy with my project. It exceeds my expectations by quite a ways. My aim from start to finish was a machine that would do serious work of course with limitations of a 20 hp diesel. It will get behind a yard or more of loose dirt and just walk away with it. There will need to be a few more revisions yet. For one thing they frame push points will need some rebuilding and probably other things yet to.
/ My mini dozer build #53
Building one of those has been on my bucket list fer years, good on ya..............(y)
/ My mini dozer build #54
Great job! Do you have any photos pushing dirt?
hugs, Brandi
/ My mini dozer build #55
What are some other / better options? (if any?) A two-bolt pillow-block is more fragile? Asking, not saying.
/ My mini dozer build #56
Just a pin and dom* pipe as the bearing. Of course with a grease zek.
*tubing made via Drawn Over Mandrel.
Pin and steel bushing is what I plan to do.
/ My mini dozer build #58
Just a pin and dom pipe as the bearing. Of course with a grease zek.
Interesting. How high of RPM would that be good for? Asking for a rototiller type design. Thanks!
/ My mini dozer build #60
I agree with what was mentioned. Pin and bushing like they use on tractors, skidloaders and other equipment.
2020 Club Car Carryall 700 Gas Utility Cart (A61567)
2020 Club Car...
2022 RBR Venturi 430 High-Capacity Pneumatic Applicator (A63688)
2022 RBR Venturi...
Bandit 250XP Wood Chipper (A63689)
Bandit 250XP Wood...
SWINGTEC D-88307 COLD FOGGING APPLICATOR (A64276)
SWINGTEC D-88307...
New/Unused Landhonor Hydraulic Quick Attach Pallet Forks (A65583)
New/Unused...
2018 LIEBHERR A900C LITRONIC WHEELED EXCAVATOR (A63276)
2018 LIEBHERR...
