My Longevity Mig200S
/ My Longevity Mig200S #1
FredH
Platinum Member
Ruch , Oregon
N.H. TC-30
First , Thank You Simon and Longevity Crew !! Ordered Wednesday , Here Saturday !!:thumbsup:
O.K. , Although not a " Big " Welder , ( i.e. miller 212 / lincoln 216 ) , By the Specs , it has as good or better duty cycle than those welders , ( Plus the 200S does Arc/Stick as well ) .
Size wise , it is bigger than my lincoln SP135 , more similar to a newer miller 140 . I would not classify the 200S as " Portable " , Weight wise , No Problem , I just think it would be rather a " Arm " load to carry around to much .
Package Very Well , so that even if the box takes a sharp blow , I doubt the machine gets touched as it sits away from the top , sides and bottom . Includes a 2# roll of wire and also a hose for gas hook-up .
Did not have any gas as my brother has my cylinder , so I change over the polarity of the gun to " negative " , ( Very easy to do , 2 knobs inside above wire feed , 1 black and 1 red , No Brainer ) .
Attached gun , locked in place with included wing stud , and attached small plug for mig gun operation , ( can't remember what the called it ) .
Attached Ground clamp plug into Positive ( + ) hole , since mig gun was changed to Negative ( - ) , As with no gas , figured I would run some flux core and give it a try .
Only had time for a few beads on some 1/2" scrap I had , Spent maybe 5 minute's playing as We have our Grandson this weekend , So He comes before toys .:thumbsup:
Pictures
Front panel
Short bead on right was first , then moved left with each bead , was welding away from me , " Push "???
Bead on left was first of these 2 , had both wire speed and voltage turned up to were voltage is in picture above . Small weld on right was with wire speed set were it is now ??
This 2 beads were last , I Think . 1 on right first , then 1 on left , with controls set were they are at in picture above .
I Think only 1 weld was made from side to side , most were push away from me due to time and not being able to set - up accordingly . Basically , Just plug it in and shot few beads , Which By the Way ,
The 3 Prong 50 Amp welding electrical plug was already Installed , So another Thank You to Simon and Longevity . Matches my 220/240 cord for my plasma cutter .
Wave Form , Never Touched . Will have to check out the cd/dvd that was included and the video's on it . Tried before going and playing , But Grandson had other Ideas so only was able to read a little .
Will Add more as I have time and " HopeFully " as some of you more Skilled , ( All of You !!!! ) , Give me advise , ( Please :D )
Fred H.
Wire was E71 flux core
/ My Longevity Mig200S #2
Cool quick post FredH. Glad you were able to capitalize on the Longevity/TBN discount deal that I was unable to use.
As you gain more practice. I would be interested in how your new unit in wire feeder mode compares to your older Lincoln SP-135 limited to within the capabilities of smaller Lincoln of course so you are comparing apples to apples. (FWIW I also have a Lincoln SP-135P mig).
Lastly, I always pull a flux core puddle to better control slag. I always thought pushing a puddle is usually limited to mig mode (aka with shield gas), but maybe I misunderstood your post and I am far from an expert so....
That's why I mentioned the " Push " I was using . Thought I was doing it Backwards , but was , as I mentioned , limited on time . My 18 month old Grandson is my Priority as far as time goes .
I'm pretty sure your right on that . Another issue I had was my helmet . Although it would Auto Darken , Seems like I kept " Losing " sight of the puddle . :(
Well , Most of You will get a Laugh out of this . Just went out with better half to show her the Welder . So I looked at the Helmet . Have not used it for awhile , since " Before " I ran a bunch of wood through the table saw . Well , To say the least , The Build up of fine saw dust / dust on the outside of the helmet glass was almost worthy of using a ice scrapper !:ashamed: That " Duh !! " Moment !!
Very Impressed with the welder just in the little time I used it . Going to hopefully run over to my Bro's house next weekend and will switch it back to solid wire and hook to a tank and see what he thinks . He is a lot better welder than I am , think he also has some stick rods around , so we will try to try that out also .
Fred H.
/ My Longevity Mig200S #4
I wonder if the wave form is like an inductance control? If so, when welding flat I'd turn it down. This will give you a flowing / wetter puddle. For vertical up welding I'd turn it up, this will give you a dryer / stiffer puddle. Now I'm only guessing on what it is.
Looks like most of your welds you're running a little slow, or you could turn your voltage up some.
What brand of flux core are you running?
I like Lincoln's NR-212, and Hobart's Fabshield 21-B.
/ My Longevity Mig200S #5
I was going to ask the same thing. Wave Form on DC?? Must be inductance. They should change that so they have common verbiage.
Think I was running slow 'cuz I could'nt see . :ashamed: I was amazed at how much garbage was built up . My wife was laughing at me , when I took a finger and swiped at the front and it left a clean streak down through it . Never even crossed my mind as I could see before striking a arc , ( Least I thought I could ?? ) .
Wire is some of a 8" roll I had of Harbor Freight E71T-GS that I had taken off my little Lincoln for some reason quite awhile back , Think it was because I did not like the way it ran on it .:confused3: In Looking at the way it ran here , Thinking it won't be ran on this welder either .:thumbdown:
Normally do run Lincoln wire , should of took the roll out of my lincoln and tried it instead . Have a new roll of lincoln .030 solid that I will load up then try with gas next weekend . See if I can do any better .
All in all though , the welder , ( THE MACHINE , not ME ) , is pretty impressive .
Fred H.
P.S. Am going to ask over on the longevity forum about the " Wave Form " , Going to also give your suggestion's a try Shield Arc . Thinking to Try same type welds , with it turned off then turned up ???
/ My Longevity Mig200S #7
Just a suggestion for practicing your welding, it is hard for anybody to make welds look good on a flat plate. Maybe think about picking up some 1" x 1/4" flatbar cut it into 6" long pieces. Practice fillets, and lap joints. If you think about it, when building things how many times do you actually weld on a flat plate? Just butting two pieces of plate together is better practice than running beads on a flat plate.
Was Reading on the Everlast site in one of their manuals and You are spot on in your description of the Wave Form . Have a Bunch of 1.5" x 1.5" x 1/8" up to 1/4" angle in a pile out back , so Your Suggestion will be Used . In re-looking at those welds , I also know why I dumped that H.F. wire out of my lincoln some time back ! Although I use Flux core in my lincoln , I normally use lincoln wire and that H.F. spool seem to have at least twice the splatter beads every were .
Fred H
/ My Longevity Mig200S #9
If you didn't wire brush those welds off, that is a bad sign having the slag hit and miss like that. I've run 5/64-inch NR-211 at well over 400-amps, and that will happen! You want complete slag coverage over the weld like this.
/ My Longevity Mig200S #10
Hi Guys,
Here are a few videos done by Scott on the MIGWELD 200S - he is just starting to do these for us, so we are doing our best in editing and learning editing. Let me know if you would like to see anything particular as we are going to do more of these videos. Also, please do not foget to subscribe to our youtube channel!
/ My Longevity Mig200S #12
Much better audio quality!
And better editing(voiceovers).
So nice to be able to hear clearly.
I look foward to more of these better quailty videos.
Got home this afternoon and ended up building a new computer for BOL , But While windows was loading went out and played with a couple of pieces of tubing out of the scrap pile .
Above is before cleaning slag
These 2 were first and had welder a little to hot / high , was burning through the tube :ashamed:
This was after cleaning slag and getting adjustments a little better .
Have to for sure retool my brain from welding with my 110/120 lincoln to this welder . :ashamed:
Hopefully get to town in morning , want to pick up some rod to see if I can rekindle any brain cells from my high school days on stick welding . That could be Really entertaining !!;)
In my case it was " Stick " Welding . Strike , Stick , Break loose , Strike , Stick , Break loose , etc....... :cool:
Fred H.
My pictures Suck !! I can build computers from scratch , but trying to take a close-up without blurring , UGH !! :confused3:
If I take my time , set up every thing " Right " , ( Clean dust off glass of helmet also helps :ashamed: ) , I am still a hack , but am able to stick things together . Last weekends 5 minutes of play was the first welding done since last spring's Land Plane build , It comes around with time .
S.A. : I really Appreciate Your Help , Thoughts and Ideas , Makes Hacks Like me a better Welder or at Least Gives Me Hope .:thumbsup:
Fred H.
/ My Longevity Mig200S #17
Many digital cameras have a "macro" button that you push for focusing on picture close-ups or else you get blury pics. I imagine even some higher end phone cameras have the feature too. I would almost guarantee that the camera you are using does if the picture is blurry. My company's expensive high dollar camera that I must use at work absolutely will not take a close-up picture without blurring unless that "macro" button is pushed.
The Beauty of this Forum , Always Learning Something . Now going to have to research camera settings . :thumbsup:
Fred H
Well , Headed to town yesterday for some metal from my supplier . Couple of pieces of 1/4" plate and was also looking for some 1/4" square tube , maybe 2" x 2" but ended up getting a section of 2" x 5" or 2" x 6" , ( forget now ) what it was . Anyway , shot over to a welding supplier and picked up a 5# box of 6011 . Got home and ran 2 rods through the 200S . Welder works fine in arc mode , ( Meaning the MACHINE!! ) . Me on the other hand , ugh !:( . First mig welding requires 1 movement , Horizontal , But Stick / Arc requires 2 movements , Both Horizontal and Vertical , ( Feeding rod is the vertical movement ) . Sorry People , Way to much Strain on this Brain at this point in my life :confused2:. Did it years ago in high school but older now and Seriously Doubt Wiser , so I am reverting back to my favorite acronym ,
KISS , Keep it Simple Stupid . ( Stupid meaning me ):confused3: . 1 Movement easier than 2 , Likely Why I don't Chew Gum either . Never would be able to walk any were .:thumbsup:
Fred H.
P.S. Actually did better than I thought , never stuck the rod , Just Never burned more than 1" off the rod at a time either , So Shield Arc is right there also , " Moving to slow " .
/ My Longevity Mig200S #20
Fred;
Where are the pictures of your stick attempts?
Perhaps a seasoned pro could provide some constructive criticism.
It does not take 30yrs to lose the hang of stick welding... A year or two will do it also!
I guess I have gotten "spoiled" with MIG also
