My Harbor Freight Quick Hitch
/ My Harbor Freight Quick Hitch
My snowblower has a bar located below the top link attachment. The top hook on the quick hitch has no way to get connected. It will not slide into place. Basically, it's not quick hitch compatible. In this case you use the adapter.
/ My Harbor Freight Quick Hitch #23
The same happens with my BB and cutter:mad:
/ My Harbor Freight Quick Hitch #24
my quote.
Originally Posted by Bedlam
...the lated catalog had the 26 inch one on sale and under had the upper LINK not the adapter but a upper link. So don't confuse the two. The adapter for the top is a different number. One that I have yet to see them post.
Ill explain, and sorry that it was so confusing. When you sometimes will see the quick hitches advertised, and see they also have the top link close to the ad.
Harbor Freight Tools - Quality Tools at the Lowest Prices
I was meaning not to confuse this item with the adapter that is availably for the quick hitch.
Call their customer service and ask for Item #29309, Description "93691 Hitch Adapter
the adapter is the upper adapter for the hitch NOT the adjustable upper LINK.
I have emailed them a couple of times and suggested that they also add the adapter to the hitch advertisement. Id think many people would also buy it. Their response was that the manufacturer doesn't want it to be advertised.
Seems a bit weird, but that was the response over a year ago now.
Just my thought that it would save allot of people the trouble of finding they need one and having to pay shipping and the delay.
The purpose of the adapter is to allow you to hook onto the upper link when the design of the implement is not able to hook to the 'J' hook.
WHITE's above picture is a reference, of the part, and you can see it in the PDF owners manual here.
http://www.harborfreight.com/manuals/93000-93999/93691.pdf
I hope this all helps.
Al
From LSU AgCenter:
ASAE Standard Quick Hitch Pin Dimensions
An ASAE standard Category 1 quick hitch actually requires Category 2 hitch pins at the top and bottom. You can buy at implement dealers and farm supply stores inexpensive bushings that you just slip over the Category 1 pins on the implement. The bushings will be labeled Cat. 1 2 upper and Cat. 1 2 lower.
If your implements conform to these dimensions, it will be easy and inexpensive to use an ASAE standard quick hitch. If your implements do not conform to these dimensions, you have three choices: (1) modify the implements, (2) use a delta-type quick hitch that will fit almost any implement (but at higher cost) or (3) don't use a quick hitch.
.........or buy a HF adapter...ha
/ My Harbor Freight Quick Hitch #26
Kendrick,
The EZ-HITCH from Carterandsonsllc.com can be custom fit to meet all of your needs.
Looks like EZ-HITCH is being advertised on any thread for quick hitch discussion. 129.00 (109.00 + 20.00 shipping). I'm into my HF (was on sale) for about 85.00 and it also takes care of the top link verses just a lower link solution only.
/ My Harbor Freight Quick Hitch #28
Got my QH at HF for $69.00. There is no problem with the lower arms attaching to your implements, it is the top hook that doesn't match up and you have to use the adapter.:rolleyes:
I bought the adapter as well. (85.00 total , hitch, adapter, shipping, 1/2 pins for the top hook when drilled).
/ My Harbor Freight Quick Hitch #30
EZ-HITCH said:
Kendrick,
Can I weld chain hooks to it?
Can I use it to yard logs?
Can I engage an attachement without getting of the tractor?
Can you sell it to me for $69.99?
These are my needs...
/ My Harbor Freight Quick Hitch #31
What adapter do you sell so I can just back up to the implement, lift, and drive off?
Total cost, with your adapter?
/ My Harbor Freight Quick Hitch #32
Ok, let me revise that statement.
The EZ-HITCH can be custom fit for any size tractor (Cat.1, 2 or 3), and they allow for width adjustment on the lower arms which the HF model does not.
You do have to dismount your tractor to hook up the top link and install the retainer pins on the hitches.
Sorry to say that, no I can't sell them for $69.99.
I purchased the HF design 3 years ago myself and found that it did not fit any of my implements, so to the drawing board I went.
I posted on this thread simply to let users know that there are other options out there.
Jerome Carter
Owner
Carter and Son's Tool & Die, LLC
/ My Harbor Freight Quick Hitch #33
Tough crowd here today!
Jerome Carter
Owner
I'll bet they'd be alot closer to $69 if some of you gentlemen would assist by working for Carter and Sons for far less than minimum wage in a hazerdous enviroment, w/o any benefits and would also vote to shield them from any liability from any loss or damages incurred from use. I also had a HF quick hitch w/ the adapter, I gave it away to escavader in Maine and he used it in the bucket of his kubota bx. I didn't find it to work well and needed mods to get it on the 3pt arms. I'm guessing they've improved it.
/ My Harbor Freight Quick Hitch #34
EZ-HITCH said:
Ok, let me revise that statement.....
Jerome,
Looking back, I guess I was part of the tough crowd here today. :eek: However, you'll have to admit, you kinda walked right into it. We we're talking about apples and made a point to tell us tell us about the splendid qualities of the oranges you sell :D
Your product does have a lot of good things going for it that I like, however.
1. It doesn't add more length to the arms like other products do.
2. It's made in the USA.
3. It's a simple rugged design.
4. It's made by and innovator and entrepreneur you who saw a need, designed a product and brought it to market.
Just my opinion, though. If you could figure out how to bring the price down below $100 (including shipping) I think you'd have a better chance of success. For many, myself included, there's a psychological barrier at $100. That, and there'd be less of a chance that a chinese copies would start showing up on the market.
Just my $0.02.
-Steve
/ My Harbor Freight Quick Hitch #35
Steve,
TOUCHE!:D
I would rather think of it as Red Apples and Green Apples, but I certainly get your point.
As for the price, there is always the issue of finding out what price the market is willing to pay for a product. I agree that they would probably sell better at $99.99, I just can't sell them at that price and make it worth my time. If I can ever get them into a retail store then I think that would be the price. I just have not been able to make that happen yet. I can't even get this site to respond to me about advertising here.
Jerome
/ My Harbor Freight Quick Hitch #36
HEY TORIN,
Been wanting to respond ,but couldnt get on.Your quick hitch in my bucket ,worked excellent with the 3 point blade i got at TSC.I tryed it on the rear of my KUBOTA just to try,and hated the plow back there[never had proper angle]so i went back to the front,its so much better.Icould really push them banks up high this winter,and boy we sure needed to!
ALAN
/ My Harbor Freight Quick Hitch #37
Bedlam said:
Call their customer service and ask for Item #29309, Description "93691 Hitch Adapter. Hope this works ...
Hello, I just got my 97214 Quick Hitch and discovered I too need the adapter for non-ASAE implements. Can you tell me if this adapter supports both models of the quick Hitch? I assume it would, but I sometimes get in trouble when I assume too much :)
Has anyone had any problems with theirs breaking or twisted under the stress? Just looking at mine, doesn't appear to be as heavy as the John Deere version.
Looks like my Leinbach landscape rake will fit with no problem. But, my Leinback Blade is not as wide. It's about 28" from end to end of the lift pins. Looks like there is a lot of extra thread on the lift pins. So, if I get some big washers I can probably add 3/4" to each side and make it fit. Just wondering if the blade is going to move left to right in the quick hitch since there will be some gap between the frame of the blade and the lower hooks on the quick hitch. Any ideas?
Thanks for all the good info in this thread...
/ My Harbor Freight Quick Hitch #38
Looks to me that ;White; the original poster bought the top adapter. perhaps he will have the number he used.
(Item #29309, Description "93691 Hitch Adapter) thats the only number that the service person gave me so I would second the assuming its the same. Seems as tho it should be. Maybe try to call them and see.
1-800-444-3353
/ My Harbor Freight Quick Hitch #39
Anyone have photo's of the adapter? Before I started making these myself I tried this design and could not get it to fit any of my implements, hence the reason for me trying to "design a better mouse trap".
I am just curious how they make it work.
/ My Harbor Freight Quick Hitch #40
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
2025 MACK GRANITE GR64F DUMP TRUCK (A63276)
2025 MACK GRANITE...
2019 KENWORTH T680 T/A 6X4 SLEEPER TRUCK TRACTOR (A59910)
2019 KENWORTH T680...
Dickson Ind. 4080 SX Turbo Blast Asphalt Surface Prep Machine (A64194)
Dickson Ind. 4080...
2012 WESTERNSTAR 4900FA (INOPERABLE) (A63569)
2012 WESTERNSTAR...
2019 Toyota Mirai Sedan (A61574)
2019 Toyota Mirai...
