My first tractor
/ My first tractor #1
1stormseekr
Agnos, Arkansas
ls mt125, belarus 250as, ferguson 30
well i just drove 250miles one way last night and baught a ferguson 30 for $600. This is my first tractor should be interesting finding out and fixing it's problems. Real easy to start so far but doesnt like to stop *grins*.
So far i need to look at the brakes, does have water in the oil, and smokes.
Havent messed with one in 15years...ahh grandfather would be so proud.
well after a while tinkering in the daylight the brakes just need pads, and it smokes like a freight train. Think it needs a headgasket, but i figure i am just going to rebuild it.
/ My first tractor #2
Congratulations on the new toy! Which motor does it have? TB
/ My first tractor
z129 4cyl gasoline, is that the info your looking for? Not up to speed on the engines of old tractors...now if it was in a muscle car i am your man.
/ My first tractor #4
A continental motor. Dont know a whole lot about the continental motors, mine is a perkins. If it smokes that bad, the pistons the rings and sleeves are probably wore out. Im guessing a headgasket is not going to stop it from smoking. Someone else might have a better idea for you. Maybe the head needs work and oil is getting by the valves, that would certainly be a cheaper and easier solution if that were the case (dont hold your breath lol). I would toy around with for awhile and see how everything works before you tear it down. I dont know how bad yours smokes, but when I bought mine it was so bad you couldnt really use it without being choked out, so I rebuilt it real soon after the purchase. Good luck, and how about a few pictures of the new toy? TB
/ My first tractor #5
They are prone to cracking between the cylinders....I had two TO30's that did that. Can be plugged and/or welded.
/ My first tractor
lol choking ****, this thing kills every insect within a mile. Taking it to fatherinlaws tomorow and we will tear into it then and see what it's problem's are. I am in luck, he is a mechanic with close to 40years in the business and has a full machinest shop! *grins* It pays to stay on his good side.
/ My first tractor #7
Start with a 10 foot pipe straight up on the exaust, that shoud put the cloud well above you:laughing: TB
2021 Ram ProMaster 3500 Box Truck, VIN # 3C7WRVLGXME588513 (A65563)
2021 Ram ProMaster...
100 Gallon Galvanized Water Tank (A65579)
100 Gallon...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
New/Unused 3 Point Hitch with Ball/Flat Hitch (A65583)
New/Unused 3 Point...
2008 Genie AWP-30 Single Manlift (A61572)
2008 Genie AWP-30...
2003 Ford E-450 Super Duty Passenger Bus (A61573)
2003 Ford E-450...
