My First REAL Tractor...Help Please!
/ My First REAL Tractor...Help Please! #1
Mamasan
OK, OK....I know that tractors are supposed to be a "guy" thing, but I can't help myself, I'm just in love with them! We recently moved to a home with 5 acres. The land was in terrible shape. I've wacked away at it with my poor little Cub Cadet 1450 and it is now halfway presentable, but some of the heavier jobs left to do, like taking the crown off of the 400' driveway, send the Cub to the back of the barn, hiding in fear.
Not having the funds necessary to buy the latest and greatest, I settled on a Kubota L285 (1976-77) which came with loader, box scraper, grader/snow blade, and brush hog. It is all in pretty good shape.
For the most part, everything works well on this tractor and it runs like a top, no smoke or knocking. The one problem it does have, though, is that the glow plug system is not working. The indicator on the dash is not glowing at all. I cannot find this part (15401-65451) online. Does anyone have any good sources for parts for an L285, new or used? Any other suggestions as to a fix? Thanks in advance. You guys are great!
http://www.tractorbynet.com/photos/showphoto.php/photo/1580/sort/1/cat/500/page/1
/ My First REAL Tractor...Help Please! #2
<font color="blue"> the glow plug system is not working. </font>
Mamasan,
Is the tractor hard starting? It could be something as simple as the indicator lamp being burned out, and the glow plugs could be working fine.
I can't help really, but you could somehow check the voltage at the glow plugs with respect to the frame and see if there is voltage there when you put the key in the "heat" position. Or you could just take the indicator bulb out and see if it is burned out...
Just a couple thoughts to get this thread going if no one answers before this post appears... /forums/images/graemlins/smile.gif
/ My First REAL Tractor...Help Please! #3
By the way,
Welcome to TBN! You will find lots of good advice here.
Don't forget to thank your tractor for its hard work (very nice, checked out the pic) on a daily basis. They tend to be quiet, after the work is done, but they do appreciate it when we thank them for their effort! /forums/images/graemlins/smile.gif
Arigoto works well for Japanese tractors...
Henro,
Thanks for the reply! The tractor will start easily on its own if the temp is 50-60 degress or warmer outside. Anything below that, she won't start without a shot of starting fluid (small shot). Your suggestion about checking the voltage is a good one. We'll get right on it! Where would I buy a new indicator lamp if needed? I apologize for the newbie questions! /forums/images/graemlins/confused.gif
/ My First REAL Tractor...Help Please! #5
I was just wondering, have you checked the resistance across the glow plugs? I have a Kubota engine running a genset and my BX are both 9 ohms. Maybe the circuit is not completeing at the indicator light due to defective or burnt plugs?
Good luck
Hi Bx,
Thanks for the response! No, this is a newly devleoped problem and we weren't sure exactly where to start. This is our first diesel. You will notice that I say "we" meaning "mine", You know...what's his is mine and what's mine is mine?
I thank you for your suggestion. We'll check it out. My first instinct was to run down and buy 4 new glow plugs, but it may be just the indicator. There doesn't seem to be any relays or resistors on this setup. Just the indicator wired straight to the plugs. It is pretty straight forward (read old).
/ My First REAL Tractor...Help Please! #7
For parts you might call tractorsmart. They have an excellent web site and are reasonably priced.
Welcome to TBN......may all your tractoring be orange!
/ My First REAL Tractor...Help Please! #8
MAMASAN,
Tractors ARE NOT a guy thing,dont ever believe it.Up here in MAINE,if it werent for the farmers wives running tractors,much of the work wouldnt get done.Ther would have been a good many wet bales of hay,etc if the women folk hadnt have been proffesionals on there tractors along side their families.In fact the dealer who sold me my tractor,is a woman,has been doing it for all her life.She can probably answer any question i have.She also demonstrated the tractor for me,and showed me how to operate it.Although i cant get my wife to try the bota,she can ride a four wheeler better than most of my buddys can.
There are no man vs women things here,but we do clown around a lot.
WELCOME to the club,post often,never be afraid of asking a question,or giving an opinion.
Escavader,
Thanks for the welcome and thanks for taking me to school on the whole man vs woman thing. I am here in a heavily populated area of Ohio and am apparently woefully unaware of the woman-tractor connection. Glad to know I am not alone! And don't try too hard to get your wife on the bota, you may never get it back! Yes, clowning is good!
SandyC,
Thanks too for the welcome and the tip on TractorSmart.com. It looks they have a lot to offer. I'll be giving them a call. Orange is beginning to be my favorite color.....
Anybody else have any tips on how to diagnose the glow plug problem?
/ My First REAL Tractor...Help Please! #10
First thing that you need to check is if the circuit is getting voltage to the switch that engages the glow plugs. Then check to see if the voltage is leaving the switch and going to the glow plugs. I believe that the light is in between the switch and the glow plugs. Check the circuits with a test lamp and also check the glow plugs with a ohm meter. If you don't understand what I am talking about, then you are already over your head and should leave the repair to a qualified technician. I don't mean this negatively or demeaning, but as a word of caution. You can do much harm trying to repair a item that you have no experience with and knowledge of. Also, make sure that you never place yourself between the tractor wheels when doing any work on the tractor. To do so, could cost you your life if the tractor was to suddenly start because you touched the wrong wire and in an instant, you could be under the tire. Experience mechanics make mistakes and die..... inexperienced people make more of them and die more often. We need to keep you around to remind us that there are a few women that know how to use tractors. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif Welcome to TBN
Junkman,
Thanks for the welcome!
Those are words of wisdom if ever I've heard any. The last thing I want to do is end up in "The Big Tractor Showroom in the Sky"! /forums/images/graemlins/crazy.gif
I am not in over my head as far as testing the circuitry and using an ohmmeter. BUT, I would not have considered the possibility that the tractor could start and lurch. Whew! Perish the thought!
Your advice is very much appreciated. That's what I like about you guys. You've been there, done that, and I haven't. I'll try to be a good student! And provide an occasional perspective from a female point of view (although you may not want to hear it...) /forums/images/graemlins/wink.gif
/ My First REAL Tractor...Help Please! #12
Welcome to TBN! You're not the only woman on here... but there aren't many! Junkman gave sound advice.. so go from there. I will also ditto what a previous poster said that Tractor Smart is a great site/store for info and parts. I've used them several times with great results.
Don't be a stranger to TBN!
/ My First REAL Tractor...Help Please! #13
As a little extra safety precaution, you might want to put the transmission in neutral, and set the parking brake (or block the rear wheels) . Then if you would happen to start the engine, it won't go anywhere.
Good Luck /forums/images/graemlins/smile.gif
/ My First REAL Tractor...Help Please! #14
I have not look at an electrical schematic for this yet, but I just wonder if the glow plug indicator is broken then there will be no power send to the glow plug. This is only true if it's in series and parallel is otherwise.
Alex
/ My First REAL Tractor...Help Please! #15
<font color="blue">Anything below that, she won't start without a shot of starting fluid (small shot). </font>
Mamasan,
I would be careful using starting fluid with a diesel. I have read that it can be the kiss of death to a diesel engine (at least ones using glow plugs). At least the kind used for gas engines.
Some use something like WD40 I think. I don't have any experience along these lines, and so I'm just reporting what others have said, somewhere within earshot of me, at sometime in the past.
Actually, come to think of it, I think starting fluid IS USED with some diesels that DO NOT have glow plugs. So using it without problem may actually be an indication that you DO have glow plugs that are not working.
Perhaps someone who knows more could add some specifics... /forums/images/graemlins/smile.gif
/ My First REAL Tractor...Help Please! #17
My 1972 international diesel does not have glow plugs. It is/was equipped with an ether injection system to allow the operator to push a button from his (or her) seat and the ether automatically injects into the intake manifold.
I have heard that once you start using ether that it takes more and more to start it. When buying a used tractor, avoid those with an ether can under the seat.
Highbeam,
Thank you for your post. The glow plug problem is new and we have only used ether a couple of times to get her started until we can diagnose and fix the system. I have to wonder, though, since your machine is actually designed to use ether, why is it so dangerous to do so? I understand that if the glow plugs are working and you use ether, you have an explosive situation and can take out your engine. But if the glow plugs are not working, or the tractor is not equipped with glow plugs, such as yours, how is the judicious use of ether bad for the engine? This is just out of curiosity as diesels are new to me. I will certainly err on the side of caution and get her fixed right away, rather than take the "easy" way out by starting her with ether. Thanks again! /forums/images/graemlins/smile.gif
/ My First REAL Tractor...Help Please! #19
I don't know about Kubota engines, but on the older Mitusbishi and Satoh diesels, the piston tops are too thin to use ether. They are glow plug engines and there is a decal on the dash that says use no ether. If you go to satohparts.com you can look at photos of a Mitsubishi diesel ruined by the use of ether. Due to this, I would lean towards not using ether on any diesel that uses glow plugs. It is especially important not to use ether if the glow plugs are working. Aside from all that, I have heard that constant use of ether rounds off the top of the top compression ring. This will result in lower compression, which then results in the need to use ether when you shouldn't have to use any assist. Someone please correct me if I am wrong on that. You may also want to consider using a block heater.
Hey Guys,
An update: It appears that the culprit most likely is the glow plug controller. I've got one on the way and hope that it does the trick.
Hubby didn't know I posted here, and since he decided that he wanted to be the "main wrench", I just sat quietly in the corner and offered an occasional "suggestion". Thanks to your advice, I must say that I appeared absolutely brilliant. /forums/images/graemlins/wink.gif
It's our little secret, let's just let him think that I am..........
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2017 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2017 FREIGHTLINER...
2021 Kubota MX6000 (A62177)
2021 Kubota MX6000...
2015 Audi A4 Sedan (A61568)
2015 Audi A4 Sedan...
Skid Steer Boxbroom Sweeper (A64047)
Skid Steer...
2007 DRAGON 130BBL VAC TRAILER (A60736)
2007 DRAGON 130BBL...
