MX5800 bucket
/ MX5800 bucket #11
Interesting info. We have a Construction Attachments 4N1 bucket on our MX5800. I really like the flexibility of a 4N1 bucket but I have thought about getting a regular bucket also. If I do, I'll buy it from Everything Attachments. Is the general recommendation to get a bucket with bolt-on teeth and also bolt-on cutting edge? Can you get both on the same bucket? Thanks.
Yes but it looks like you have to remove the bolt on cutting edge to install the teeth or the tooth bar.
/ MX5800 bucket
The L2296 bucket holds slightly less than the standard bucket, considerably less than the light materials bucket.
L2296 weighs approximately 100 pounds more than the standard bucket.
LINK: kubota l2296 bucket - Google Search
I recommend a pair of 5/16"/Grade 70 Ken's weld-on chain grab hooks for your L2296 bucket, fused approximately in line with FEL arms to distribute torque.
Ken's Bolt on Grab Hooks <<Weld-On>>
LINK: 5/16" bucket hooks site:tractorbynet.com - Google Search
Copy that, appreciate all the help. Yep, 2 of those grab hooks are on the books for the FEL. Do you recommended 3/8" or 5/16" or does it depend on chain size?
/ MX5800 bucket #14
5/16" grab hook holds 3/8", 5/16" and 1/4" chain securely. It is the closest thing there is to a universal size.
You want to buy 5/16" Grade 70 chain, not 3/8" lesser grade chain. Lowe's and Home Depot have good prices for bagged 5/16" chain with a grab hook on each end. in their hardware/trailer section. Have the store divide into a 12' length + 8' length and add Ken's slip hooks to the two new ends.
Grade 70 chain is very difficult to cut at home.
/ MX5800 bucket #15
I have an HLA standard duty bucket on my MX5100 that is 3/16 material with 1/4 sides. It is really heavy duty and therefore weighs a lot. it takes about 3/4 cu yd of material stacked and I use it for moving mushroom soil. The bucket weighs close to 500 lbs and is plenty tough. I got it when I purchased the tractor and is shown on tractor
2019 ALLMAND LIGHT PLANT (A60736)
2019 ALLMAND LIGHT...
(INOP) MASSEY FERGUSON 1552 TRACTOR (A59823)
(INOP) MASSEY...
2017 Ford Escape SUV (A59231)
2017 Ford Escape...
2016 Ford Explorer AWD SUV (A59231)
2016 Ford Explorer...
429970 (A61165)
429970 (A61165)
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
