MX5800 bucket
/ MX5800 bucket #1
coolbrze
VA
Kubota MX5800
Think this might be my last ? re: the new MX5800HST. Well... probably not haha. Is the L2235 a good bucket or should I get a heavier duty one? Will be using the FEL for dirt work, rocks, logs, & pretty much everything else you can imagine. I'm hard on equipment so don't mind upgrading if I should but if it's a decent bucket, I'll keep it.
/ MX5800 bucket #2
Easy - HD one. Bought it when I got my 2012 MX and still not a dent or bend. I often use it for moving dirt/logs/etc....
/ MX5800 bucket #3
HD bucket with the (BOE) bolt on cutting edge is the only way to go , At this point what's a few more dollars:D
/ MX5800 bucket #5
I have the L2296 Heavy Duty Round-Back bucket too. You do not have to baby the L2296.
Provides a rigid mount for a Bucket Spade and Debris Forks and other bucket attachments.
/ MX5800 bucket
Thanks. Anyone have pics of either the QA light material bucket, the QA square back bucket, or the QA HD round back bucket? Are the 3 buckets the same size?
/ MX5800 bucket
Provides a rigid mount for a Bucket Spade and Debris Forks.
Good looking bucket Jeff, looks tough! Also looks bigger than the light material bucket but maybe it's just the pic?
/ MX5800 bucket #8
/ MX5800 bucket #9
/ MX5800 bucket #10
Interesting info. We have a Construction Attachments 4N1 bucket on our MX5800. I really like the flexibility of a 4N1 bucket but I have thought about getting a regular bucket also. If I do, I'll buy it from Everything Attachments. Is the general recommendation to get a bucket with bolt-on teeth and also bolt-on cutting edge? Can you get both on the same bucket? Thanks.
/ MX5800 bucket #11
Yes but it looks like you have to remove the bolt on cutting edge to install the teeth or the tooth bar.
/ MX5800 bucket
The L2296 bucket holds slightly less than the standard bucket, considerably less than the light materials bucket.
L2296 weighs approximately 100 pounds more than the standard bucket.
LINK: kubota l2296 bucket - Google Search
I recommend a pair of 5/16"/Grade 70 Ken's weld-on chain grab hooks for your L2296 bucket, fused approximately in line with FEL arms to distribute torque.
Ken's Bolt on Grab Hooks <<Weld-On>>
LINK: 5/16" bucket hooks site:tractorbynet.com - Google Search
Copy that, appreciate all the help. Yep, 2 of those grab hooks are on the books for the FEL. Do you recommended 3/8" or 5/16" or does it depend on chain size?
/ MX5800 bucket #14
5/16" grab hook holds 3/8", 5/16" and 1/4" chain securely. It is the closest thing there is to a universal size.
You want to buy 5/16" Grade 70 chain, not 3/8" lesser grade chain. Lowe's and Home Depot have good prices for bagged 5/16" chain with a grab hook on each end. in their hardware/trailer section. Have the store divide into a 12' length + 8' length and add Ken's slip hooks to the two new ends.
Grade 70 chain is very difficult to cut at home.
/ MX5800 bucket #15
I have an HLA standard duty bucket on my MX5100 that is 3/16 material with 1/4 sides. It is really heavy duty and therefore weighs a lot. it takes about 3/4 cu yd of material stacked and I use it for moving mushroom soil. The bucket weighs close to 500 lbs and is plenty tough. I got it when I purchased the tractor and is shown on tractor
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
(INOP) 2013 MACK ELITE LEU633 GARBAGE TRUCK (A62130)
(INOP) 2013 MACK...
DURA-CAST PRO-LICK TANK (A62131)
DURA-CAST PRO-LICK...
2021 John Deere W48R Walk Behind Zero Turn (A63116)
2021 John Deere...
Tater Squeeze Chute (A61166)
Tater Squeeze...
2015 Chevrolet Silverado 3500 4x4 Service/Welding Truck, VIN # 1GC2KYEG3FZ124159 (A61165)
2015 Chevrolet...
