Must Have Shop Items
   / Must Have Shop Items #181
How does that switch control 220V? Wouldn't it just shut off one leg?
   / Must Have Shop Items #182
A Shop is also good for a Marriage. A little distance between you on occasion can be a good thing.
My wife enjoys that I have an all weather shop just as much as I do. She is rarely out here and doesn't stay long unless she's got a project going on in here. :D
   / Must Have Shop Items #183
I think the 120v lighting circuit energizes the contactor which pulls in and provides the 220v. It's just a big solenoid.
   / Must Have Shop Items #184
Yeah, that's how mine works.
He's using a double pole toggle wall switch. I'm not an electrician at all. I didn't know you could buy a switch like that to run a 220V air compressor motor.
   / Must Have Shop Items #185
Usually just an electro-magnetic contactor and is used on large motors and fans.
   / Must Have Shop Items #186
Well, I asked if he was using a contactor and he said no, just a wall switch. So that lead me to believe he's supplying 220V to a wall box, connecting the switch, running 220V out of the box to his compressor?? Curious to hear confirmation.
   / Must Have Shop Items #187
I believe it is a 220v 30 amp switch he is using. That is how I interpreted it.
I’ll shut up now because my electrical knowledge is pretty minimal.
   / Must Have Shop Items #188
I'm sure you are way ahead of me Terry. That's what I thought he meant as well.
In my particular case my compressor is at opposite ends of the shop from man door. I would have had to run power the length of the building twice. But in other circumstances I can see the advantage. And it saves the cost of the contactor.
   / Must Have Shop Items #189
The linked switch is a double pole switch, so it would shut off both sides of the 220 and he just has to have power to the air compressor go through that switch.
I plan on doing something similar, but with a crank timer type switch. I found a 2 Pole crank timer switch that will be installed in line between the panel and the air compressor and turn off the air compressor when the timer runs out.
Aaron Z
   / Must Have Shop Items #190
Aaron Z
That's a new one me too. So can you explain the crank timer a little more? I manually select a time period or program it or what? Thanks!!!
2012 John Deere 6170R (A57148)
2012 John Deere...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2013 Ditch Witch XT855 Tracked Loader (A56438)
2013 Ditch Witch...
2018 Kubota RTV500 4x4 Diesel Utility Cart (A59228)
2018 Kubota RTV500...
SEMI AUTOMATIC...
2014 CATERPILLAR 627K SCRAPER (A60429)
2014 CATERPILLAR...
