Mule oil pressure switch
/ Mule oil pressure switch #1
2diamondfarm
Bronze Member
West Michigan
TYM 574, Deere 4410, Gehl 353 Mini Ex
I have a 2016 Kawasaki mule that will not start and the oil lite is blinking, did a little research and the oil pressure switches do go bad and cause a rank no start like I have .
So I ordered a new one and they are different where the wire hooks on the old one hade a spade where the wire hooked on.
The new one has a screw on the end . I called the dealer where I ordered it from and left a message .
So should I change the connection on the machine so it fits order the screw ?
/ Mule oil pressure switch #2
A quick and dirty test would be to put a ring terminal on a scrap of wire and fold the other end over so it goes into the spade terminal, do a test and see if it runs. If it does, change the wire terminal to a ring.
That’s what I was thinking
Did that still has the light and no start☹️
I also check the gas , oil and all the fuses that I could find
/ Mule oil pressure switch #5
Does it turn over at all?
I have a 2016 Mule 4010 that would turn over, but would not start. I found that I was not getting power to the injectors. I was about to change the control module, when a mechanic determined that a wire was broken in the wire harness. Instead of taking the harness apart, he added a wire on the outside of the harness, and that worked.
I have since had to re-do the connections he made because they didn't last. I think I have good connections now, because it hasn't happened in a good while.
Yes it turns over just no start
/ Mule oil pressure switch #7
Check for spark. If none, check any Darwin switches that might be there for blade or seat positions, if they ring out I'd look to see if the oil switch wire has a short to ground somewhere. If you don't have a wiring diagram, you might find one on manualsonline or manualslib, makes it a lot easier chasing things.
If you have spark, that would likely be a fuel issue.
Has spark
/ Mule oil pressure switch #9
Have you tried putting a gauge inplace of the sensor and making sure engine is producing oil pressure
/ Mule oil pressure switch #10
Some switches are normal open, some are normal closed. Since the terminations are different, i hope he gave you correct switch
Update
I ended up taking in to have it looked at and it was the battery .
apparently it can have enough voltage to turn the starter but not the fuel pump at the same time .
Live and learn
/ Mule oil pressure switch #12
Hopefully that solves your problem. Batteries can be finicky and will do weird things.
/ Mule oil pressure switch #13
well thats one i would not have guessed
2014 International Derrick Digger Truck (A55973)
2014 International...
2010 International 4300 2,000 Gallon Water Truck (A55973)
2010 International...
Deere 310SK (A57148)
Kholer Magnum 10 Compressor (A61307)
Kholer Magnum 10...
2016 Ford Explorer AWD SUV (A59231)
2016 Ford Explorer...
2008 Mercury Milan Sedan (A59231)
2008 Mercury Milan...
