Mule Gets Hitched
/ Mule Gets Hitched #1
GeneD14
Tennessee
Kubota B26 TLB, Allis Chalmers D17 series IV, Kubota ZG-23 Mower, Kubota ZD 1211, Kawasaki Mule 610, Stihl 361, Stihl 045 AV Super, and a Stihl 660 Ported and tuned
On our new Kawasaki Mule we needed a tow hitch. We want to use it to pull a lawn roller, dump cart, etc... Excuse the driver, he is a little goofy.
/ Mule Gets Hitched
I started to fabricate one by extending the frame tubes using 1.5" black pipe. I drilled a through hole bo bolt the extentions on.
/ Mule Gets Hitched
I then tacked up the hitch out of some scrap steel that I had. I wanted to make sure that it all fit correctly before final welding. I also added a tow hook that could be used with a tow strap.
/ Mule Gets Hitched
Once I was sure that everything was lined up right I welded it all up and put a coat of primer and black paint on.
/ Mule Gets Hitched
Another view.
/ Mule Gets Hitched #6
Looks good and a good idea to utilize existing tubes. The only problem that I can see is that it will ride rough when you have something hooked up, since it is attached to the axle swing arm.
/ Mule Gets Hitched
And one last picture... Not quite as big of a project as WroughtHarv would typically tackle, but I've had enough for now. /forums/images/graemlins/laugh.gif
/ Mule Gets Hitched
</font><font color="blue" class="small">( Looks good and a good idea to utilize existing tubes. The only problem that I can see is that it will ride rough when you have something hooked up, since it is attached to the axle swing arm. )</font>
Jerry,
I had trouble finding anything to mount the hitch to. There just isn't very much back there.
I want to make a front brush guard and bumper and it looks like a challenge to find anything solid enough up front also.
/ Mule Gets Hitched
Here is a light gauge metal Mule hitch that is selling now on Ebay for $104. It appears to simple bolt to the center of the lower control arm.
Unused 2022 Loftness 14CFISV3 Auxiliary Hydraulic Oil Cooler Skid Steer Attachment (A66734)
Unused 2022...
RANGER S/A TRAILER W/WELDER (A67714)
RANGER S/A TRAILER...
More info coming soon. (A64557)
More info coming...
2000 KENWORTH T800 CRANE TRUCK (A67714)
2000 KENWORTH T800...
2017KENWORTH T270 SERVICE TRUCK (A65057)
2017KENWORTH T270...
2014 ISUZU NPR S/A 4X2 17FT BOX TRUCK (A69167)
2014 ISUZU NPR S/A...
