MT1601D hydraulics
/ MT1601D hydraulics #1
bigcheese
Ferris, Texas
Mitsubishi MT1601D
Messed up and left tractor out in hard rain, transmission shifter boot is torn and water contaminated hydraulic oil. Drained and flushed system twice, but cannot get hydraulics back up and working other than implement lift will raise slowly, used to raise fast. Did I mess up the pump too? Have flow but no high pressure.
Yes, mine uses standard hydraulic oil in the trans which is the hydraulic resorvoir.
/ MT1601D hydraulics #4
You've probably got air in the system and you'll have to work the control valve some more to bleed it off. If you don't have a loader installed, use 80 wt gear oil. The shift boot is cheaper that the oil you've bought. Email me for a quote. Bill - satohparts.com.
UNUSED KUBOTA BT4554 - 17" PIN ON BUCKET (A64280)
UNUSED KUBOTA...
UNUSED WOLVERINE UNIVERSAL MOUNTING PLATE (A64281)
UNUSED WOLVERINE...
BUNDLE OF (3) 2" X 20' (3) 1 1/2" X 20' (3) 1" X 2 (A64281)
BUNDLE OF (3) 2" X...
FORD SUPER DUTY TAILGATE (A64281)
FORD SUPER DUTY...
2018 CATERPILLAR 232D SKID STEER (A64279)
2018 CATERPILLAR...
LOOK! (A63111)
LOOK! (A63111)
