Mowing mowing over sandy soil
/ mowing over sandy soil #1
windfall
i live in the sandhills of south caroliona. we keep about 7 acres of area cut with a finish mower.over the last 20 years i have been through a number of different types of mowers and mowing decks(small ford lgt,bush hog finish mowers etc). every time we mow it is like sand blasting the blades and the under side of the deck.has anyone had this experience ,dose any one know of something that will help extend the life of the decks in this situation. we have tried low lift blades,but it dose not help much.
/ mowing over sandy soil #2
Don't have suggestion re: blades,
But if you had a HEAVY coat of "undercoating" sprayed under the deck it would act some what like sandblast resist and might help.
/ mowing over sandy soil #3
What about coating the underside of the deck w/one of those spray on bedliner type materials? That stuff is pretty durable. Might save/delay the deck wearing out....
/ mowing over sandy soil #4
There was a thread similar to this a few weeks back. Try searching for deck coating, or undercoating, something like that. There is some product made specifically for mowing decks that is supposed to not foul the deck outflow. Spray-on bedliner will probably cause a lot of clogging of the outflow.
/ mowing over sandy soil #5
I think the undercoat was Lubriplate Graphite Paint. He painted the underside and also the blades. Try a search on it.
Hope I got it right!
Wally
thanks for the info .i had some tnoughts about the bedliner spray , but i had never heard of that paint i will reseach it
/ mowing over sandy soil #7
windfall said:
thanks for the info .i had some tnoughts about the bed liner spray , but i had never heard of that paint i will research it
Dixie Chopper has already tried many coatings, but the sand eats just about anything, except tire rubber. If you can some how bolt strips of tire rubber to the underside of the deck, it will not sandblast the deck. I repaired some sandblast spots in front of my right rear tire, where the blades sling the most sand. It is still there after three years. Now , about the blades, they are the culprit, I use the Gator blades, and it eats the front edge and the trailing edge. Hard surfacing might help a little bit. but is not cost effective. Best bet is a low profile cheap blade. I used a vacuum system also, and the sand would eat the impeller tips, and the housing. We beefed up theunit, by welding 1/4 steel around the vacuum housing and that gave more longevity. Here in Florida, sand is a big problem also.
/ mowing over sandy soil #8
Wally
Big Dad here..... Deck graphite guy. I'm afraid that the sand would clean that graphite right off. I knew a guy that had a cabin on the Miss and he Stellited (sp) the leading and trailing edges of his blades. The cutting edge was a bugger to get sharp after that, but it saved him replacing blades all the time.
Good luck!
/ mowing over sandy soil #9
I guess it's just part of the operation of that type mower. To get away from sand eating up decks or blades, you have to get away from that type mower. If you do that, like say a reel type mower, then you have the problem of adjusting, sharpening, etc. all the time, and having to mow more to keep the grass short, or they don't work well. Good luck with finding a solution. Maybe mow a smaller area and put livestock on the rest.
/ mowing over sandy soil #10
You can get blades that are hard coated for wear resistance. They cost 4x a normal blade.
jb
/ mowing over sandy soil #11
Yeah, interesting thread.
Sand is sand and there is a reason it used as a hardcore abrasive for removing paint and the hardest of finishes.
I've heard of the Rhino/Dura-liner material being used for extending the life of various pieces of equipment including a shredder. As noted above, it's some pretty resilient stuff and I'd use it in a heartbeat to proof and shield a sensitive unit......hardens like metal and waterproofs like rubber.
It'd be good for proofing your mower's deck, but, the blades are what they are and coating them with anything will kill their effectiveness. Teflon? Might shield some abrasion but will also effectively "dull" the blades as well.
As a poster above noted, unless you're willing to line your unit with strips of used rubber, a coat of this is the best for the deck and living with the wear and replacement of your blades in probably the best option.
/ mowing over sandy soil #12
Ruberized truck bed liner sprayed or applied to every surface but the cutting edge..
soundguy
PAN (A62613)
PAN (A62613)
PREVIEW DATES AND TIMES (A65563)
PREVIEW DATES AND...
John Deere 5000-Series Tractor Grill Guard (A65640)
John Deere...
John Deere 6200 Tractor (A64047)
John Deere 6200...
2022 EZ-GO ELITE...
2012 PETERBILT 367 (A65643)
2012 PETERBILT 367...
