mower unit smoking!
/ mower unit smoking! #1
grabbit
John Deere D130
Have a Yanmar 146 which I just bought. Used for the second time and mowing unit slowed down and started smoking like crazy..almost caught grass on fire.
Smelled like burning rubber.
The blades and belts rotate easily by hand, belts look ok. Do not see any obstructions anywhere. I had just greased up the deck when I bought it.
Any suggestions?
T.
/ mower unit smoking! #2
I get this a lot on my riding mower. It is always an obstruction, either a stick, grass buildup, or wire wrapped around blade shaft. If you're sure there are no obstructions try starting it again and engage the blades. Sometimes whatever was blocking it falls off.
/ mower unit smoking! #3
I would take a close look at the belt routing, and belt guides etc. See if it's rubbing on something. Trust your nose, if you smell rubber burning it probably is.
/ mower unit smoking! #4
Yea that and that and make sure any idler pullys will spin easy.
/ mower unit smoking! #5
did you grease up all the spindles? Any that are loose? Had one loose the bearing and it got HOT, burned the belt pretty bad after it shot hot metal everywhere.
jb
I ran it again tonight, no smoke, but did smell, and belt melted in several places and kicked off!! It was too hot to touch.
Prior to running again, I inspected it again and cannot find any obstructions. I could move belts and blades with ease. I did grease the 3 ports a couple weeks ago.
Are there bearings in there that need to be replaced? If so, does anyone have directions on how to fix, p/n etc?
When I bought the tractor a couple weeks ago the seller did prewarn me the mower unit was super loud, which it is. He said he checked the bearings and appeared to be ok. ?? It has 1600 hours on it.
/ mower unit smoking! #7
Every thing you're reporting here sounds like a bad bearing, either in one of the spindles or idler pulleys or even more than one.
The only way to test is to remove the belt tension to where you can easily spin each spindle and idler pulley independantly. In this way you can find the offending bearing.
A good bearing will spin easily, feel smooth and not make any loud noises. A bearing that labors to spin, or feels rough or makes any kind of unusual noises is bad.
Good luck
The 3 main spindles with grease ports spin ok. yes, they were recently greased.
There is one pulley, without a grease port (is this the idler pulley?) that catches once in a while. I poured some gearlube oil over it to let it soak in.
IF I were to replace it, are there generic brands I can install without costing an arm and a leg?
Ordered a new mower belt and cost me $90!! I thought my JD $30 was expensive. If I knew YM parts were hard to find and expensive, would not have bought this. Just afraid of melting off the new belt, which will get expensive real fast!
/ mower unit smoking! #9
To generate that kind of heat the belt has to be sliding on one or more of the pulleys. As stated earlier, an obstruction, a bad bearing or mis-routing or tensioning could cause it. A too loose belt would slip on good pulleys and bearings and cause the problem. If everthing spins as its supposed to, I would check the routing and belt tensioning device very carefully.
/ mower unit smoking! #10
Tractor Supply usually has a good selection of pulleys.
You may be able to replace the bearings in the pulley you have, might be easier to go that route.
/ mower unit smoking! #11
Before you install that new "golden" belt, write down all the numbers on it somewhere you can locate easily. Another suggestion would be to waltz it down to the local parts house and show it to them, get the replacement part number and belt lenght/size. It is easier to find one now when it isn't stretched and mutilated.
That done, start turning each pulley slowly and lightly by hand, feeling the hesitations if any in the turning. Might not be much but it should show up if you have a bad bearing.
David from jax
2014 MAC FLAMELESS HEATER (A68842)
2014 MAC FLAMELESS...
2 PALLETS OF SNOW CHAINS (A66091)
2 PALLETS OF SNOW...
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
6 1/4 INCH OD 90 DEGREE ELBOWS (A67714)
6 1/4 INCH OD 90...
2015 Freightliner M2 106 Hawk H-1150TL Forestry Grapple Truck (A66736)
2015 Freightliner...
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
