Mower deck: AEMAHMX60 - midmower unit
/ Mower deck: AEMAHMX60 - midmower unit #1
BlackOps
Platinum Member
northern middle tn
Mahindra Max 25
does anyone have a manual for this in pdf format or even jpg? i have some exploded parts view but the whole pto unit is missing in the diagram - it has the main unit parts listed and not the shaft info included. - my unit is and has been frozen for a few years now due to many surgeries. and it only has like 3 hrs maybe 4 at most on it. so i am trying to see what i can do before another big service and transpo bill.
thank you.
sorry for extra info - this works with the max 25 (HST) model.
Ok i sent a few days lubing and pb balstering and breakfreeing the actual pto shaft and the push/pull ring at the end that attaches the shaft to the tractor pto. they WERE frozen! so now i have to try to get the top housing off and see what is underneath and lube all that up and see of i can unfrezze that aspect. The i will have to try to flip it over somehow and see what is happening underneath the actual midmower unit. any comments or information to help me along i would greatly appreciate it very much. after an expensive tractor in the shop this past 2 months i am trying to figure this unit out and fox what i can on my own. Thank you so much everyone.
/ Mower deck: AEMAHMX60 - midmower unit #4
Here’s a generic manual for the deck, out in the garage I have a hard copy of one that came with my deck, very detailed. I’ll take some pictures of the drive train section tomorrow if I get a chance.
  • MM60.pdf
wow!!! THank you again so very much. this will help me a lot. just a stupid question for my next step: the belt covers on top of the deck. are the bolts welded or part of the deck or do they fall through the bottom? - are they all the way through? do you have to be able to access both top and bottom to remove the nuts for the covers?
i hope to tackle this within the next day or so.
/ Mower deck: AEMAHMX60 - midmower unit #6
Hope these help out. If yours is the same deck, there are 4 bolts per cover, item 7 in the parts diagram you remove and the cover comes off. No need to get under it.
Man you have been so helpful over the years here. thank you. may have a go at it this morning. :))
2007 MACK CTP713N TRI/A DUMP TRUCK (A59914)
2007 MACK CTP713N...
24" BUCKET (A64277)
24" BUCKET (A64277)
1992 GMC C7000 Dump Truck, VIN # 1GDM7H1J9NJ522223 (A65563)
1992 GMC C7000...
2021 Case IH Steiger 540 Tractor (A66285)
2021 Case IH...
Rol-Air gas powered portable air compressor, Coal Valley, IL (A65640)
Rol-Air gas...
2015 Chevrolet Silverado 3500 Pickup Truck, VIN # 1GB4KZC88FF627993 (A65563)
2015 Chevrolet...
