Grading Mower blade sharpening
/ Mower blade sharpening #1
JDgreen227
Super Member
Central Michigan
4210 MFWD Ehydro--'89 JD 318
I don't know if anyone else has posted this idea, but it worked well for me. In mid-season I like to sharpen the blades on my 7-Iron deck, but it's heavy and difficult to remove and reinstall. Driving up on ramps gives enough clearance to remove the blades, but it's a pain trying to wedge a wood block into the blades to prevent them from turning while you loosen or tighten the mounting bolts.
My solution is to attach a length of 12/2 electrical wire to a chain grab hook, slip the hook onto the mower blade, and wrap the other end of the wire around something atop the mower deck...it works GREAT.
I am /forums/images/graemlins/mad.gif at myself for not thinking of this trick years ago.
/ Mower blade sharpening #2
Or just use the good old air gun to whizz them off!
Do you have the 60'' 7 iron mounted on your 4000 series tractor? I had one on the 4300 and it cut the best cut you could ever want.
2001 Sea Breeze RV (A62613)
2001 Sea Breeze RV...
2011 Jeep Grand Cherokee AWD SUV (A61574)
2011 Jeep Grand...
2009 Toyota Camry Hybrid Sedan (A61574)
2009 Toyota Camry...
2005 Sterling Acterra Tender Truck (A63688)
2005 Sterling...
2012 VOLVO SD105DX SMOOTH DRUM ROLLER (A64279)
2012 VOLVO SD105DX...
Bobcat Skidsteer (A60352)
Bobcat Skidsteer...
