Moving loader up without starting engine.
/ Moving loader up without starting engine.
Why can't you just remove the bucket?
From my original post: The Front End Loader is down on the ground (nothing attached).
The bucket is not attached.
/ Moving loader up without starting engine. #23
Can't you just pull back the stick while it's cranking? The starter ought to have enough grunt to slowly move some oil thru the lines. Or is the motor stuck ?
/ Moving loader up without starting engine. #24
I was thinking the same thing. Or has the OP thought about using a jack with control in float.
/ Moving loader up without starting engine. #25
Uh, guys; very first sentence of post #1 - "My L5740 won't turn over."
Glad to see I'm not the ONLY one that misses stuff like that :laughing: ... Steve
/ Moving loader up without starting engine. #26
Have you tried using a jack.
Yep. I jacked it a little way up and it seemed to hold for a while. If it comes down to having it towed, I'll probably use the other tractor's FEL to pick this one up a bit and/or just let the tow truck driver do the cable under the loader trick mentioned earler.
After putting the loader in float, I used the loader on the M7060 to raise it up and get some jack stands under it. I'll be making a couple of braces out of angle iron tomorrow. I'll strap them to the cylinder rods and then get the tractor taken in to the shop.
Thanks for all the advice.
/ Moving loader up without starting engine. #29
You use correct terminology.
- - Some people use "turn over" or "crank over" as start, so it always has to be verified to be sure what is being described.
/ Moving loader up without starting engine. #30
Thanks; in a few of my "past lives" I taught electronic equipment repair, re-wrote manuals on imported video equipment, did phone troubleshooting before resorting to expensive service calls, etc - it taught me to avoid sentences like "throw the horse over the fence - some hay" - my "smart-a**" side also wants to add that, in some steeper places on my land "not turning over" is a GOOD thing (more correctly, not overturning maybe??) :laughing: ... Steve
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
New/Unused ATS 13000 Pound Electric Winch (A65583)
New/Unused ATS...
2006 Cadillac GM Superior Coach 6-Door Limousine - Only 21,567 Miles (A63688)
2006 Cadillac GM...
KBH Tender Trailer (A63688)
KBH Tender Trailer...
1984 Charles Machine Works S4A S/A Tilt Deck Trailer (A61573)
1984 Charles...
2015 RAM 4500 HD 4x4 Service Truck (A62613)
2015 RAM 4500 HD...
