motor locked up
/ motor locked up #1
u2cme21999
case david brown
hello,
I started my old case david brown yesterday,cold start did not plug in heater,started tractor,ran for maybe 2 min. blew lot of black smoke and stalled engine,now it wont turn over,have a brand new batt. in it,is it possiable the engine could have locked up somehow?
thank you for any help,
Lester
/ motor locked up #2
Suggest looking at the battery cables and all connections from the battery to the starter to ensure all is good. Then note if there is any kind of sound from the starter when you try and start it.
Next try a manual bar over. :)
/ motor locked up
when i turn the key the starter engages,but motor dont turn over,manual bar over,what is that?
/ motor locked up #4
just what it sounds like.
try to manual spin the engine over by hand. that usually entails a breaker bar and big socket on the crank nut.
what model of cdb is it?
did you check oil and coolant prior to start?
soundguy
/ motor locked up #5
You might be hydrostaticly locked. If this is a diesel pull all injectors. Keep fuel shut off and turn over if possible. If gas pull sparkplugs and do same.
Good luck.
/ motor locked up #6
Put the tractor in reverse (engine off) and grab the rear tire and pull forward (rocking it back and forth). It will cause the engine to spin backward. I've seen this done before and sometimes it will free up a stuck engine or starter bendix that has jammed on the flywheel.
May not solve your problem but it's easy enough to try.
/ motor locked up #7
hello,
........ blew lot of black smoke and stalled engine,............
Lester
What do you mean when "and stalled the engine". ??
You stalled it doing some work or moving the tractor, or the engine stalled out on its own ?
If on its own, then I'd suspect fuel related problems.
If it stalled when you let out the clutch or when you put the engine under load, then could be locked up. Might be lubrication problem.
More info needed here.
/ motor locked up
thank you for all the info. i'll each reply till i get it freed up,it was whenb i let the clutch out that it stalled,thank you again for the info.
Lester
/ motor locked up #9
If the tractor sits outside uncovered. It's possible you have water in the transmission and,or rear differental. The water froze enough the lock the driveline somewhere. Cover it with a tarp and shoot a torpedo heater at it. Warm it up. Rock it enough to unbind the engine. It might be fine. Just drain the transmission and rear differental fluids and replace with fresh. This happened to a diesel tractor at the farm. It had a bad trans shifter boot. Let water into transmission.
/ motor locked up #10
he should still be able to start it with the clutch pressed, unless it is an independednt pto model.
if it is in 2 gears it could bind.. but again, as above.
soundguy
CASE INTERNATIONAL 21' FIELD CULTIVATOR (A63291)
CASE INTERNATIONAL...
2004 Cadillac Eagle Ultimate Hearse, Eagle Coachbuilders, Hearse Collector Special (A63689)
2004 Cadillac...
2018 HINO 338 KNUCKLE BOOM TRUCK (A63276)
2018 HINO 338...
(INOP) 2002 CHEVROLET 3500 BUS (A59823)
(INOP) 2002...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A61306)
2016 RAM 5500...
Athey 7-12D Force Feed Loader (A62679)
Athey 7-12D Force...
