Well, I'm here to help.... haahhaaa
First, visit the mole man and find out real information about your new adversary.
Mole control, biology and trapping help, 1986, professional, author, tom schmidt | The Mole Man
The first year I had mole problems, they undermined our swimming pool, causing the bottom to collapse, tearing the liner and sending 12,500 gallons of water through my garage. Game on!!!!
That was August and I killed 29 of them with traps before the ground froze.
Year 2 I started trapping as soon as I saw signs of them, and stopped counting at 50 confirmed dead moles.
Year 3 I did the same, stopping the count at 50 again.
Year's 4,5 & 6 same thing.
So I'm up to over 300 moles in 6 years.... ON ONE ACRE!
Then, years 7-10, I only killed about a dozen, and every year since, I only see one or two. It's been at least 15 years. I figure somewhere between 350-400 now.
Here's what you do. Go buy yourself a couple Victor Out O' Sight mole traps. They are about $12.00 each (I have 6).
Learn how to set them. They can be set in any soil type at any depth. They are extremely durable, last decades, work very well, and seldom miss when triggered. They also kill the mole very fast VS a lot of other traps that don't. You want to be as humane as possible.
Moles are meat eaters. Earthworms are their primary food. They also eat insect larvae like grubs. They dig two types of tunnels. One is a highway tunnel to get from point A to point B. The other is a feeding tunnel. That's where they explore for food, and tear up the lawn like a wrinkled carpet. It's about hopeless to trap the feeding tunnels. Trap the highways. And don't bother with the mounds.
To find the highways, look along building edges, sidewalks, foundations, and right under fences. Any object that they run into they tend to tunnel along. Those are the most productive tunnels to trap.
Take your heel and press the tunnel down in several places. Check your heel marks later in the day or the next morning. Anywhere your heel mark has been pressed back up is an active tunnel. Place your traps on the active tunnels.
Buy yourself a pack of marker flags on the little wires. Use those to mark your heel marks. It makes things a lot easier.
Trap the perimiter of your property and the interior. Moles are a bit territorial, so once you kill a few, others will move in on the same tunnels. By trapping the interior, you kill the home based moles. Then trap the perimiter to get the ones that are tying to move in. Once you clear out the interior, you just need to keep tabs on the perimiter.
Any questions, I'd be happy to address. Good luck. :thumbsup:
