Mold and grass buildup on mower deck underside
   / Mold and grass buildup on mower deck underside #31
When I read "on", I thought it was a typo.
"For sure, me meant 'in', right?"
Nope! :ROFLMAO:
Hey TMK... they rust less if you put the in the container, over winter! :p
   / Mold and grass buildup on mower deck underside #32
I use my pressure washer under my 12' mower. The 3 decks lift up hydraulically so easily accessible. It can be a little messy but it gets the job done.
   / Mold and grass buildup on mower deck underside #33
Nope! :ROFLMAO:
The 10-footer wouldn't fit inside, and while the 5 and 6-footers technically would there's so much...um...good stuff inside it that nothing more does.
Thankfully, they don't rust anyway because of our climate.
   / Mold and grass buildup on mower deck underside #34
As others have said there is no good way to prevent this when mowing wet grass, especially with a bagger attached. I do lawncare as a side gig and scraping is just part of the job if I have to mow wet grass. As for leaving the buildup to harden, all that does is make it more difficult to scrape and the trapped moisture will corrode the deck eventually.
   / Mold and grass buildup on mower deck underside #35
My neighbor was cleaning his mower deck and got some of the oldy moldy grass in his eye which turned it nasty(my professional opinion. lol) . Claimed the doctor said getting poop in it would have been better than the nasty stuff. lol.
   / Mold and grass buildup on mower deck underside #36
My kids get angry with me if I stick the cerial box on the top shelf in the kitchen cabinets.
"Hey dad, where's the mower?"
   / Mold and grass buildup on mower deck underside #37
The only trick is driving your tractor up there to hook them back up 😀
   / Mold and grass buildup on mower deck underside #38
No reason to get the tractor involved for such a simple task.
   / Mold and grass buildup on mower deck underside #39
I have a JD x590 with 48" deck and it collects a lot of grass and has to be cleaned frequently. Cutting wet grass is a real problem. Does anyone know if a mulching kit would eliminate grass buildup?
   / Mold and grass buildup on mower deck underside #40
My experience is that it makes it worse because there are more baffles to catch the grass under the deck.
2025 12V Diesel Pump and Hose with Meter (A50324)
2025 12V Diesel...
2024 New Holland Skid Steer (A52377)
2024 New Holland...
2004 Caterpillar 345B Hydraulic Excavator (A53421)
2004 Caterpillar...
BUSH HOG 1815R1 BATWING MOWER (A51406)
BUSH HOG 1815R1...
2011 Kubota KX080-3 Midi Excavator (A55787)
2011 Kubota...
2010 FORD F750 XL SUPER DUTY DUMP TRUCK (A51406)
2010 FORD F750 XL...
