Too many Kubotas
And what bad happens if leaving the crud in place? On my mowers it tends to eventually fall off by itself.
Other than mid to late summer, our grass is always wet. I mowed today, it hasn't rained since last week, and it was still wet and sticky. It clumps in every crevace under the deck like concrete, over time.I had to mow up north. It was tall and wet, no choice. It’s been raining so much there this year, I had to cut on a day that there was a break in rain. Looks like my next trip will be cleaning the crap stuck under the deck. I probably should have used the finish mower behind the T25 instead of the JD. It was slow going.
Made a stop out of rectangular tubing I slip over one of the lift cylinder rods as I'm also wary of the FEL coming down. That eliminates it.I've been doing the same off and on for years, not as religiously as I should, but there are only so many hours in each week. I've taken to jamming a big wood block (LVL section) under the rig after lifting, ever since having had a hose failure on my loader while lifting a brush hog / rotary mower deck to clean under it.
You'd think a loader probably bleeds down relatively slowly when a hose fails, but nope... mine came crashing down like a sack of bricks dropped from a window. Even relatively young and athletic, I was maybe 40 when that happened, there's not a snowball's chance in hell that I'd have been able to get out from under that rig as fast as it came crashing down. Thankfully I was 20 feet away, turning on the hose, when it happened.
Back in the eighties, I took a seasonal job with the local county parks department maintaining mostly rural parks, out of town, some on gravel roads. Each day, coming in we douched out every mower. Period. All klnds of mowers, tractor flails, ZTR, conventional, walk behinds, riders, all of them. My ol 'man was a stickler on keeping his gear cleaned and lubed, tractors, trailers, and I have it in my blood to do the same. I have gone through three used JD riders, and still have one, plus a x370 now with 110 hours on it. It looks like new.true story.I have a John Deere D140 with a bagger that I use for the first few mows of the season to prevent all the dandelion seed distribution. I know it's not ideal to mow wet grass, but sometimes that isn't an option, and the grass has to get done (even though it means stopping every few laps and unclogging the chute to the bags).
I went out to the garage yesterday after mowing the lawn and could smell the wet grass under the mower deck. I took it off and spent the next two hours with a putty knife and wire brush scraping the grass off. It varied in depth from almost a thin wax like coating, to about three inches in some spots.
I have scraped most of it off I do believe, but would like to do something to it to prevent this from becoming an every time I mow thing. And yes, I will attempt to get the lawn mowed late afternoon, early evening when it is at its driest, but again, not always an option, and I will be ordering some new high lift blades to hopefully help with moving the cut grass across the deck and up the shoot.
Not sure if I will have to remove the blades and then pulleys to do a proper sanding, priming and painting/treating, or if there is some magic trick I can just apply now?
Thanks in advance folks.
All true, but really depends as much on deck material and thickness, as fab'd versus stamped. You're equating fab'd decks with thicker steel, which is usually true, but some stamped decks are also a lot heavier than others.The issue with cud under the deck is, it turns acidic so if left there like over the winter, it promotes corrosion. Not a big deal with a fabricated deck as you have some meat under there but a stamped deck, certainly.
My wife's ZTR has the washout things I've never used. My diesel Kubota's is really thick and heavy, but I still clean it. The guy down the road has a Hustler and never cleaned the deck and it rusted out and he had to buy a new deck.
Well, if it's in the garage, can't open the door and not be overtaken by the molding grass smell. It grows large white fuzzy mold all over it.And what bad happens if leaving the crud in place? On my mowers it tends to eventually fall off by itself.
The 10-footer wouldn't fit inside, and while the 5 and 6-footers technically would there's so much...um...good stuff inside it that nothing more does.When I read "on", I thought it was a typo.
"For sure, me meant 'in', right?"
Nope!
Hey TMK... they rust less if you put the in the container, over winter!![]()
My kids get angry with me if I stick the cerial box on the top shelf in the kitchen cabinets.The 10-footer wouldn't fit inside, and while the 5 and 6-footers technically would there's so much...um...good stuff inside it that nothing more does.
Thankfully, they don't rust anyway because of our climate.
The only trick is driving your tractor up there to hook them back upThe 10-footer wouldn't fit inside, and while the 5 and 6-footers technically would there's so much...um...good stuff inside it that nothing more does.
My experience is that it makes it worse because there are more baffles to catch the grass under the deck.I have a JD x590 with 48" deck and it collects a lot of grass and has to be cleaned frequently. Cutting wet grass is a real problem. Does anyone know if a mulching kit would eliminate grass buildup?
