Modified Stump Grinder
/ Modified Stump Grinder #1
JohninCT
Platinum Member
Central CT
Struck Magnatrac 6000, Kioti DK40SE
Thought you PT'ers might want to check out the modified PT stump grinder that I mated up to my Magnatrac backhoe.
Pix are posted in the "build it" forum under subject "Stump Grinder".
The grinder uses the hyd motor and cutter wheel from a PT 425 stump grinder. The Magnatrac has similar hydraulic PTO capabilities as the PT 425 machine, so all I had to do was build a bracket to attach it to my machine.
John in CT
/ Modified Stump Grinder #3
Wow! That thing has some reach mounted on the end of a back-hoe! Seriously, watch out for the flying debris. Mine has bounced a few rocks off my head a time or two...(luckily, I happened to be wearing a cheap hard-hat I picked up from Harbor Freight... /forums/images/graemlins/cool.gif)
Nice work, John! Now, figure out how you could turn the stump grinder into a chipper/shredder, and I'll bet you could take quite a few orders from some of the PT owners! /forums/images/graemlins/shocked.gif
Dave
2015 DITCH WITCH FX25 VACUUM TRAILER (A63276)
2015 DITCH WITCH...
Tropic Trailer 18ft T/A Flatbed Equipment Trailer (A64553)
Tropic Trailer...
2000 STERLING T/A DAY CAB ROAD TRACTOR (A64278)
2000 STERLING T/A...
2012 CATERPILLAR D8T HIGH TRACK CRAWLER DOZER (A65053)
2012 CATERPILLAR...
155 (A64278)
155 (A64278)
2012 Caterpillar Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
2012 Caterpillar...
