Modified Stump Grinder
/ Modified Stump Grinder #1
JohninCT
Platinum Member
Central CT
Struck Magnatrac 6000, Kioti DK40SE
Thought you PT'ers might want to check out the modified PT stump grinder that I mated up to my Magnatrac backhoe.
Pix are posted in the "build it" forum under subject "Stump Grinder".
The grinder uses the hyd motor and cutter wheel from a PT 425 stump grinder. The Magnatrac has similar hydraulic PTO capabilities as the PT 425 machine, so all I had to do was build a bracket to attach it to my machine.
John in CT
/ Modified Stump Grinder #3
Wow! That thing has some reach mounted on the end of a back-hoe! Seriously, watch out for the flying debris. Mine has bounced a few rocks off my head a time or two...(luckily, I happened to be wearing a cheap hard-hat I picked up from Harbor Freight... /forums/images/graemlins/cool.gif)
Nice work, John! Now, figure out how you could turn the stump grinder into a chipper/shredder, and I'll bet you could take quite a few orders from some of the PT owners! /forums/images/graemlins/shocked.gif
Dave
Bigfoot Yard Art (A64557)
Bigfoot Yard Art...
2021 TORO 07411EX CART (A66091)
2021 TORO 07411EX...
2012 Allmand Nite-Lite Pro II 8KW Towable Light Tower (A64194)
2012 Allmand...
2018 Tycrop Vector Belt 22ft. VB-16H Sand Belt (A64194)
2018 Tycrop Vector...
2016 Ford Escape AWD SUV (A64557)
2016 Ford Escape...
LOT OF YETTER SHARK TOOTH TRASH WHEEL UNIT MOUNTED (A64278)
LOT OF YETTER...
