MMM Blade Speed
/ MMM Blade Speed #1
The Gardener
New Hampshire
BX24 MMM 54"
BX24 MMM 60"
F3680 60"
F3680 72"
B7800 MMM 60"
Do all of these mower decks spin their grass cutting blades at the same speed?
Do they all use the same Kubota blades?
I am trying to better understand why one option may produce a better finish cut than the others - assuming this is true.
Thanks!
The Gardener
/ MMM Blade Speed #2
The 54" MMM has a fairly high lift blade. It is meant to be a fine cut finish mower, and it does do that in my opinion.
/ MMM Blade Speed #3
The Gardener said:
BX24 MMM 54"
BX24 MMM 60"
F3680 60"
F3680 72"
B7800 MMM 60"
Thanks!
The Gardener
The longer the blade, the slower the blade RPM simply because if you did not adjust the RPM, the tip speed would be so fast on larger diameter blades that you could approach the speed of sound, something I understand you avoid. Lift has as much to do with the type of soil you have as well as what your trying to do ie., mulch or move the grass out of the deck. A dry sandy soil with a high lift blade will wear the blade out very quickly as well as make a tremendous amount of dust.
Engine (A59228)
Engine (A59228)
2017 CATERPILLAR 420F2 BACKHOE (A60429)
2017 CATERPILLAR...
John Deere R15 Rotary Cutter (A64047)
John Deere R15...
2015 Toyota RAV4 SUV (A61574)
2015 Toyota RAV4...
2022 New Holland Boomer 45 (A64126)
2022 New Holland...
2021 VERMEER LP573XDT VACUUM TRAILER (A63276)
2021 VERMEER...
