Mini split questions?
/ Mini split questions? #91
Set the temperature and take the remote before guests arrive. Problem solved.
My splits have Wi-Fi connection so I can monitor and set temperatures remotely.
Might be easier to keep the remote and get rid of the guests :D
/ Mini split questions? #92
I found this to be the solution to the infrared controller that Lennox supplied with my one ton mini. It will control temp within a degree while it was plus or minus several degrees with the infrared. Nice to be able to control via smartphone when you're relaxing and need to adjust the temp just a tad.
This unit heats/cools a sunroom where the temp can vary quickly depending on where the sun is at a given point in time.
/ Mini split questions? #93
Great find, just ordered two of them to test out.
/ Mini split questions? #94
There were a couple issues when controlling the Lennox with the Cielo for which I called their tech support. Their support is awesome in spite of the language accent.
/ Mini split questions? #95
I got two of these from Amazon. They hooked up in minutes and finally a much needed solution to my mini splits.
What I really like:
  • I can control my units now remotely
  • They can run on schedules (really nice for my guest house and office). I have day, night and weekend schedules programmed
  • They have a mode where you can lock mins/maxes so guests can set it outside of the range
  • Integrates with Alexa
  • Shows you what the indoor temp and humidity levels are.
/ Mini split questions? #96
What I really like:
What brand of mini splits are you running?
/ Mini split questions? #98
I see these type adds quite often on Facebook. What gives, is the price just the installation? Misleading, I would say and I'm not even in the market.
Edit: Now that I see the foreign characters in the URL, its obviously just another scam.
/ Mini split questions? #99
I also use the Cielo Breeze Eco devices to control my four Fujitsu mini splits in the house as well as the Daikin unit in my shop. I'm pleased with their performance once I got used to pointing the remote at the Cielo device instead of the mini split. If you don't do this, the units can get out of sync.
The Cielo's are also cheaper than the separate WiFi devices sold by Fujitsu and Daikin. It's great to be able to control all 5 units with a single app instead of separate ones for each manufacturer.
They are on sale now direct from Cielo with free shipping:
/ Mini split questions? #100
I think swreeder has a good solution.
2019 Chevrolet Silverado 1500 Crew Cab 4X4 Pickup Truck (A60352)
2019 Chevrolet...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
1995 HEIL  ALUMINUM TANKER TRAILER (A60736)
1995 HEIL...
GENIE SUPER LIFT CONTRACTOR (A60736)
GENIE SUPER LIFT...
2001 Ford F-150 4x4 Pickup Truck (A59230)
2001 Ford F-150...
