Middle Buster/ Subsoiler
/ Middle Buster/ Subsoiler #1
Loghomeguy
Jerseyville, IL
John Deere 4044
Here is my Middle Buster/ tater plow/subsoiler that I built. I was looking at them online and some of the cheaper ones were only 30 or 40 pounds shipping weight. The heaviest and most expensive was 100 pounds. I thought "**** I can build one better than that. So I did. I bet mine weighs 150 lbs. I ordered the 14" middle buster blade and the "ripper blade". Even though they said they weren't interchangeable I figured it wasn't nothing a cutting torch wouldn't fix. I just slotted one bolt hole. Anyway I plowed eight rows of taters out with it today and it worked "just like store bought".
/ Middle Buster/ Subsoiler #2
Looks good!
Do you think it would be prudent to incorporate a shear pin type deal in case you encounter an immovable object?
A shear pin would be a good idea. Especially if you have roots. Which I don't have, but may give it a think.
/ Middle Buster/ Subsoiler #4
I would guess your tractor would stop moving forward before you bust anything on that. I am interested to know why you moved the check chains on the lower link arms.
New/Unused AGROTK 72in Quick Attach Brush Cutter (A65583)
New/Unused AGROTK...
John Deere Hay Spear (A64126)
John Deere Hay...
AGT Cat 320 Coupler (A65583)
AGT Cat 320...
Stryker 1.5 yard Slide in Spreader Box  (A62679)
Stryker 1.5 yard...
KUBOTA SVL97-2 SKID STEER (A65053)
KUBOTA SVL97-2...
Sellick S80 (A60462)
