Mid PTO coupler
/ Mid PTO coupler #1
Trail builder
2010 Kubota BX 25
I am trying to find a coupler to connect a hydraulic pump to the mid PTO on my BX 25.
/ Mid PTO coupler #2
If you get the diameter of the shaft and the spline count, you should be able to get one from a farm supply dealer, like TSC or Rural King. If not, try your local Kubota dealer.
/ Mid PTO coupler #5
I have a number of these shafts from a few implements (mostly front mowers and snowblowers and brooms). They are all different brands and models, too. JD, Ford/New Holland, etc. Some Some are spline to spline and others are spline to 1" round shaft, either drilled for a shear bolt or a keyway deal.
I have found a few from U-Pullit type junkyards, and some from auctions where they have a mid or front mower only, and even from Craigslist and FB marketplace.
Just count the splines. 15 as I recall on my F-935 mower and 1070 tractor.
You won't believe what they cost new. Cheapest one I've seen (New Holland cm274) is about $700 and the Deere is over $1000. so, buying a rusty mower deck with a drive shaft for $50 is a darn good deal. Air compressor attachment is also a nice occasional use for a mid-pto. Tank or no tank works effectively. Don't forget the safety-blow off valve !
/ Mid PTO coupler #6
2014 Ram 2500 4x4 Crew Cab Pickup Truck (A64194)
2014 Ram 2500 4x4...
2021 Ford F550 4X4 Service Crane Truck (A62613)
2021 Ford F550 4X4...
2025 44in. Hydraulic Stump Bucket Mini Skid Steer Attachment (A61572)
2025 44in...
2007 International 4400 S/A Dump Truck (A61573)
2007 International...
6' X 20' TRI-AXLE GOOSENECK TRAILER (A64280)
6' X 20' TRI-AXLE...
Adams Tender / Magnolia Trailer (A61307)
Adams Tender /...
