Mid PTO coupler
/ Mid PTO coupler #1
Trail builder
2010 Kubota BX 25
I am trying to find a coupler to connect a hydraulic pump to the mid PTO on my BX 25.
/ Mid PTO coupler #2
If you get the diameter of the shaft and the spline count, you should be able to get one from a farm supply dealer, like TSC or Rural King. If not, try your local Kubota dealer.
/ Mid PTO coupler #5
I have a number of these shafts from a few implements (mostly front mowers and snowblowers and brooms). They are all different brands and models, too. JD, Ford/New Holland, etc. Some Some are spline to spline and others are spline to 1" round shaft, either drilled for a shear bolt or a keyway deal.
I have found a few from U-Pullit type junkyards, and some from auctions where they have a mid or front mower only, and even from Craigslist and FB marketplace.
Just count the splines. 15 as I recall on my F-935 mower and 1070 tractor.
You won't believe what they cost new. Cheapest one I've seen (New Holland cm274) is about $700 and the Deere is over $1000. so, buying a rusty mower deck with a drive shaft for $50 is a darn good deal. Air compressor attachment is also a nice occasional use for a mid-pto. Tank or no tank works effectively. Don't forget the safety-blow off valve !
/ Mid PTO coupler #6
