Mice
My niece placed Irish Spring bars all over my dad’s house. When my wife and I tore it down some of those bars were gnawed to half size. Found one dead mouse in electrical box that shorted and electrocuted - very effective. Moth balls have worked well in my Mini-ex the past 6 years. Squirrels had eaten 11 circuits in a week between using it and it not starting. Spliced new wire across the missing spaces, packed armrests and fuse box with moth balls and no more problem. Neighbor had a horse euthanized, hauled it into his dead cow disposal area. Vet said it wouldn’t cause a problem. Two days later he took a dead cow out and found 3 dead protected raptors plus 2 dying so he dug a trench large enough to bury the horse carcass. Since then I’ve been Leary of poison, especially since we have so many hawks and eagles around, but having hay and grain around can be such a lure I found I need to use some poison. My combine and largest tractor have a rodent repellent made with balsam oil in the cab and engine compartment. Had to use that tractor Saturday - very powerful odor but for once no mice scrambling from the engine compartment when I started it. Going to get some more but not useful in open areas like a building.
Good evening, I live off grid and have every rodent possible, I have been using FRESH CAB POUCHES in my tractor , truck , 5th wheel and have had very good luck with it, no damage on anything last 2 years get it on AMAZON .Dan
Over the years I've tried every "hocus-pocus" solution to ridding my RV, boat, garage, and equipment of destructive nesting mice. Soap, minted mothballs, dryer sheets, you name it, they all failed miserably. I couldn't use poisons because of our cats and our wildlife including owls and hawks who like to dine on the little destructors. I've been using a product with great results. It kills the mouse by dehydration and does not cause harm to the rodent's preditors. The product is widely available at home stores, etc. Its is called RatX and MouseX, it will set you back 15 to 20 bucks for a bag.
The best defense is offense so we have a cat squad patrolling the perimeter. Females are usually more effective than toms but the only female out there was so pretty we promoted her to house duty.
My weapons this year are bucket traps. I want to kill them where I can dispose of the bodies. I am catching about 5 per week so far but the mortality rate is diminishing (got 12 the first week). I hope that means they are working reasonably well.
If I still have problems, I will use poisons like D-Con
How many cats you have outside? I'm looking to get another male to make a total of 3 cats.
My female cat either was eaten by another predator or wandered off and taken by someone.
I like female cats but don't want to spend $60 to have them fixed.
or shot because they killed someone's birds!..
Same here, just empty the bucket on a regular basis, go down to the water and bury them at sea. No poison needed, just peanut butter.
2014 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2014 Ford F-150...
2016 Freightliner M2 106 Ambulance (A59230)
2016 Freightliner...
2024 CATERPILLAR 255 SKID STEER (A52709)
2024 CATERPILLAR...
60" HYD BRUSH CUTTER (A52706)
60" HYD BRUSH...
Ford 8510 (A53317)
Ford 8510 (A53317)
1983 INTERNATIONAL S SERIES WATER TRUCK (A52707)
1983 INTERNATIONAL...
