Mice mischief
/ Mice mischief #21
No question Fuddy - the SUPERIOR solution. I've had cats - on/off - for years. The problem - can't train them to stay home at night. Owls & coyotes just love cats, for snacks.
I have that exact same issue: great horned owls or coyotes always get the cats after a few months.
/ Mice mischief #23
There are two formulations of Tom cat: one with warfarin, the other with bromalide. The latter is more toxic to rodents. And yes, both types are still sold. I saw them at tractor supply a few weeks ago.
Good to know it's still available. The toxic formula is banned in many states though, including mine.
Maybe I should try buying on line.
/ Mice mischief #24
I have actually had good results (dead mice) with both formulations, so I went back to buying the cheaper product (Warfarin). But the other is supposed to be more toxic to rodents.
/ Mice mischief #25
I know coyotes get cats, didn't know great horned owls did though. Cats are great inside a building, barn, horse stable, etc. You wouldn't have wild animals in there.
/ Mice mischief #26
Cats just like to go prowling outside after dark. Then the owls and coyotes get them.
/ Mice mischief #27
I can't/won't use poison: too many critters; and having rodents crawl in somewhere and die can be problematic. Bucket traps and the plastic Victor traps that have the "serving bowl" in them (pack in peanut butter and it can last several catches) both work great; but they're a management/maintenance issue- just kind of accept it as a way of life...
If you have larger rodents just tie the traps off so they're not carted away.
/ Mice mischief #28
I've switched to Tom Cat glue traps. A little more pricey. New design has white plastic and lime green glue, which helps to see what you catch. I've also found securing them somehow helps them from being carried/pulled away. There also "rat sized" traps, which are nice.
I've tried the electric zapper style too. Waste of $$. There were barn cats here when I moved in. I caught too many them in my live traps, needed for the raccoon infestation, which I've now got under control.
2021 Chevrolet Silverado 2500 HD Royal Service Truck (A64194)
2021 Chevrolet...
2019 COLEMAN BT200X MINI-BIKE (A64280)
2019 COLEMAN...
UNUSED 2023 JCB S3246E ELECTRIC SCISSOR LIFT (A65053)
UNUSED 2023 JCB...
2012 MACK GU713 DUMP TRUCK (A63276)
2012 MACK GU713...
2018 VOLVO SD75B SMOOTH DRUM ROLLER (A65053)
2018 VOLVO SD75B...
TEST YOUR BID BUTTON! (A65053)
TEST YOUR BID...
