My (hopefully not ill advised) foray to the dark side...
/ My (hopefully not ill advised) foray to the dark side... #21
The TBN is by far the best and most informative " Tractor website " on the net, but before I joined up here I used to be a member of another website,
You see! I too was an orange tractor owner, I had an L-series 140 it was a CUT 1 cyl. diesel that I restored, No one could ever tell me the year make, the person whom I purchased it fro 12-13 years ago told me he thought it was a '49 but ran like a new one and could hold its own for its size and age:thumbsup: It is when I got a FEL to install onto it and soon realize the loader was much too large for that tractor, Rather than getting a smaller FEL I chose to get a larger tractor,;) and is now where I am today with my My-1700, I wish I could have afford to hold onto the Ol-bota. quite a lot of seat time on that little dude, but I really had no use for 2 tractor's on my size property,
If you cannot find info you need here on TBN, go check these folks out, They are into restoring older Kubota's and might could be of some help locating used parts:thumbsup:
OrangeTractorTalks - Everything Kubota - Powered by vBulletin
incidentally here is a photo of my old L-140
Deep, how is the RR track mounted on the front of the kuboo?
/ My (hopefully not ill advised) foray to the dark side... #22
DeepnDirt, that's a nice looking machine! How did it work for you, was the single cylinder rough, or loud? I'll check out that other forum. Thanks for the lead.
International, The 1 cylinder was a smooth running engine and could tach up some torque when needed, also could be idle down to a hit and mis,;)
I was told it had a piston the size of a coffee can :D when you think of a 1-cyl engine the first thing comes to mind is a B&S lawn engine, Certainly not the case with this diesel;) one might think it had 30 hp.:D The rice tires were much better when I first got the tractor and it got great traction to be only 2-wd. it had locking diff and a strong 3-pnt lift, It truly amazed me with all the things it could do, Far beyond what one would think such a small tractor with only 1 cyl. could do,:thumbsup:
/ My (hopefully not ill advised) foray to the dark side... #23
Funny you should ask:cool: the R/R track wasn't actually mounted it was only strapped on with some Romax wire to hold it in place for the time I needed it, the tractor had wheel weights but wasn't quite enough when using the brush cutter, so I had to improvise:D by using what was suppose to be my bench-top anvil, The bumper protrude enough so that the R/R simply laid on the bumper, I just needed a way to strap in down,:thumbsup: when I sold the tractor my plans were to keep the pc of R/R ..... The deal was when selling the tractors was to let the cutter go with it,
The one pc of equipment that required extra ballast weight, when the man attempted to load the tractor & cutter onto his trailer as he got to the deck of the trailer the front-end lift up, I thought quick as i was standing on the trailer quiding him on and jumped onto the front bumper bringing it back down, when he got the tractor loaded, he ask does it do that often? my reply was only with the brush cutter, I then showed him the weight I use when using the cutter, next thing I knew he had me talked in to throwing in my pc of R/R anvil,:cool: I would rather give him the anvil than to hear of him killed on the 6:00 news from flipping over the tractor,;) I had that pc of R/R for 30+ years:( been almost 2 years now and I've still not replaced the R/R track and probably never will,
That stuff isn't as easy to come by as once was,
/ My (hopefully not ill advised) foray to the dark side... #24
A friend of mine has a B6000 also, and I have watched him in the years past toying with his play pretty.
Some of the minor things he has done, was move the seat by making a modified bracket to allow just a little more legroom. Kind of a move it slightly backwards and upwards at the same time. Really mad a lot of difference.
As far as your Kubota "having had a reverser" on it, MAYBE, but just from pictures of these all over the 'net and my friends, is it possible that it had a tiller on it? The tiller they seemed to favor was mounted right up against the back of the housing using housing bolts and might give a thumbprint to make you think there was a reverser. Reverser's are a lot less common than the tiller. I inquired to a friend about considering making them, but not sure if the market is there for the trouble to write the programs and do the prototypes, etc.
Funny, his has a piece of railroad track on the front also...
A front end loader is in the designing stages, probably modified from a 4300 JD that I captured after a fire. A little more legroom is also being looked at, by adding a square/rectangle to the existing section that couples the front end to the rear end. Several modifications to the 3pt have come along, as different pieces have become available. The last mod was from the above listed JD, which has worked rather well. His tractor came with the tiller attached and the 3pt hitch has to be removed to install the tiller, so he didn't acquire that stuff when he purchased it.Engine horse power is said to be 13, and from most basic stuff, is very similar to the Ford 1100, as far as size and capabilities. Doubt that is another source of parts, though.
Please post pictures of the front end problems as you work through it, as that is, and hopefully remains an untouched part of my friends tractor. It would be good information to know since the addition of a FEL is good cause for the demise of the front ends, which are really lightweight to start with.
Most of the pto powered attachments my friend uses have been modified to run from normal direction to the reverse operation. Not an easy task, but so far nothing he has wanted to use has been unachievable. Making what he wants for the tractor is part of his therapy, that most of us achieve by seat time.
The charging systems and coolant systems on these tractors are a little strange to most of us, as they don't have typical alternators, and no water pumps.
David from jax
David, thank you for that feedback. When I pull the front apart I'll let you guys know about the thread I'll post in the Kubota forum.
I think it had something else on it because there is some bracketry around the PTO output that doesn't look necessary to mount the tiller, and it has an adapter to take it to a 6 spline 1 3/8 output, which is obviously an American market aftermarket addition. I wasn't meaning to take a picture of that part of it, but you can kind of see it in this picture: B6000 :: B6000rear.jpg picture by International284 - Photobucket
What did your friend modify for this machine, and how? If he needs any pictures of the loader mount or bracketry or whatever, I'll be happy to take some pictures or do whatever I can.
DeepnDirt, it's interesting to hear about that big single cylinder engine. The two cylinder engines are notorious for having more torque than the three cylinder engines of the same horsepower. I would imagine the difference is about that again to a single cylinder. I wish I could see one, that would be really interesting. It probably started pretty well, too, with the single big piston.
/ My (hopefully not ill advised) foray to the dark side... #26
I won't clutter your thread with irrelevant photos - but I thought a few of you might like to see a really big Eicher twin, maybe single, that was designed in Bavaria then subsequently built/used in India. We saw a lot of them there. These are rated to haul a several-ton trailer as well as typical farm use. The idle is unreal. Chuff ... chuff ... chuff. Rated peak output is at = 900 ~ 1100 rpm. In 2004 I posted some photos I took when we visited younger daughter who was studying in India as her semester abroad.
http://www.tractorbynet.com/forums/all-other-brands/47640-eicher-india.html
/ My (hopefully not ill advised) foray to the dark side... #27
I found a piece about 15"s long here about a month ago that was cut off after a patch on the RR. Lets just say it was laying around discarded.:ashamed:
There was also about a 6-7 ft piece, maybe what was cutout? I also have about a 6ft pice that was scrapped last year that i aquired out of the weeds as they had already scrapped it all and left it?
But i ride parallel for about 15+ miles of it at least twice a day on my way to work i see lots of it. And then on our way to town i pass another 10 miles of it if i go that way. I was getting about a 1ft "anvil" last year and the wife talked me out of it. Those 30ft pieces are still layed in the same spot but the small piece is gone. :mad:
I tore apart the front knuckle, and am going to post a link to the discoveries I've made. In the meantime, I thought people may want to see what I was talking about when I was commenting that some of the inspection and service items are not user friendly.
Here is the radiator cap. You kind of have to rattle it around to get it out. Obviously, how the hood lies, you can't see into the radiator to check for fluid. You have to use a dipstick somehow. Filling it is also a chore, requiring either a funnel or tiny containers.
The impossible dipstick: It took awhile to find it, even though there's not that many places to hide. I was looking for somewhere I could reach it. Here it is: (The round thing in the middle)
This thing is so small, perspective makes it tricky to tell from the picture how big things are. Here is my pointer finger trying to fit into the hole. As a frame of reference, it's still almost 3 inches away from the stick!
The other side, from the bottom, is no better either. Inside the circle you can see my two fingers and the dipstick. That's as far in as my hand will go. I still can't touch it.
/ My (hopefully not ill advised) foray to the dark side... #29
This is all part of the price payed to make something so compact.
You're right, of course, Winston. Making it small compresses everything together. However, it wouldn't have been a big deal to put an extended dipstick on or something. Same with the radiator-a parallelogram hood opening could swing it forward a bit, and give a sight into the cap, and allow for filling. There's nothing wrong with the machine, mind you. It's impressive this little guy has likely spent the better part of 40 years working his tail off, and still runs great. But corners were cut in the design and layout of things. If you're my size, it's impossible to check the oil without long needle nosed pliers. I'm certain that meant the previous operators didn't check it daily, either! :laughing:
/ My (hopefully not ill advised) foray to the dark side... #31
284,
That is the same knuckle design Toyota and every other straight front 4wd axle company uses very durable and serviceable as long as the seals stay good which is where things start going bad on them. cool
The pup sure is cute! :thumbsup:
Car Doc, the first thing I thought of when I saw the insides of this axle was "This looks just like an FJ40, but with U-joints rather than CVs." It's going to be tough to keep lubricated, but I think I'll fill it with grease, and try to pack it around the seals, then put in gear lube.
/ My (hopefully not ill advised) foray to the dark side... #33
There ya go FJ all the way! :thumbsup:
Of course you remember on them they had that 1/4 pipe plug somewhere on the side of the outer knuckle and we packed it all good putting it together and put a half tube gun grease in once she was assembled...hth. ;)
This little guy has about the same thing, but I think it's a 1/8" plug (Or metric equivalent-3mm or so?) and I had the same idea. I don't know what kind of condition the felts and packing are in, but even new they don't seem to hold well anyway, so I figure the thickest grease I can find to pack, and then dump some gear lube in to get the hub reduction gears, and just plan on adding some every couple months...
/ My (hopefully not ill advised) foray to the dark side... #35
Yeah agreed they all leaked no matter what we did just the nature of the beast!
I always said to my customers that didn't like it that - when they quit leaking thats when we will start worrying about it. ;)
/ My (hopefully not ill advised) foray to the dark side... #36
Hi 284, I'm sandmans friend with the B6000 and i think you are correct in assuming that it had a reverser, the bracket that is still attached looks like the back of this reverser shot..
you can see the three mounting bolts ( bottom right, left, and center ) that would match up to your bracket in this shot..
Keep the radiator full, this thing has no water pump. it works off of Thermo-siphon, when it's full you can see the fluid when you pop the cap, even at an angle.:D
Also i think you need to reroute that hydraulic hose, then you can reach the dip stick, mines a snap to get to. if you need anything, just shout.
Dserf101, thanks for the pictures! I wish I had the reverser, it would make this thing a lot more valuable.
The problem with the hydraulic hose is that it is connected to a hydraulic pump. I'll have to remount the pump somewhere else, I guess. I'm not sure what to do, I'm going to go check it out though. Thanks for the heads up. What do you run with your machine? What trouble, if any, have you had?
/ My (hopefully not ill advised) foray to the dark side... #38
I have a finnish mower that had to be rigged to run backwards (reversed blades and change of the belt tensionser ) a 4' box blade with scarifier's, and a tiller that i had to rebuild that came with it. I'll post some more pictures tomorrow when i have some light.
I see you have automotive rims on back. What are those from? One of our other members, John Deere 3720, is looking for a way to put R4 or turf or mud terrain tires or something on his YM169D. Maybe your machine can give him a hand?
Those pictures of the box blade look really good. Is it built from scratch?
/ My (hopefully not ill advised) foray to the dark side... #40
Just a side note, to the building capabilities of Mr. Dserf101, is he is the one that fabricated the Davagrader that I have, from stuff that I supplied.
You really should get him to post a picture of the seat bracket, as that really made the little tractor a lot more comfortable, by pushing the seat back and upwards, giving much more leg room. Box blade started life as some standard channel iron, till it got in front of Dserf101's torch. Just the right size, works great. I think a standard cutting edge might be in the works to replace the existing one.
http://www.tractorbynet.com/forums/build-yourself/175396-dava-grader-process.html
David from jax
2017 Chevrolet Tahoe SUV (A59231)
2017 Chevrolet...
2012 VOLVO VNL (A55745)
2012 VOLVO VNL...
2018 Buick Encore SUV (A59231)
2018 Buick Encore...
UNUSED SDLANCH SDLL60 STAND ON SKID STEER (A60430)
UNUSED SDLANCH...
2020 DY TP90 TRAILER MOUNTER CONCRETE PUMP (A59905)
2020 DY TP90...
Unused 2025 CFG Industrial H15R Mini Excavator (A59228)
Unused 2025 CFG...
