MGM Eagle 2420
/ MGM Eagle 2420 #1
Tigerted
Anyone ever hear of an MGM Eagle Tractor? I googled it and found very little. I am assuming this is a Chinese tractor. Kinda want to get an idea on ease of service, parts, add ons. Found what I think to be a good deal on a 24hp tractor with a rough cut mower and disc. However, a good deal now may not mean squat if I can't fix it when it breaks.
/ MGM Eagle 2420 #2
Pretty sure it is a 200 series Jinma, 2 wheel drive.
Probably has the Yangdong engine. Should be on the engine tag.
Parts should not be a problem.
Ronald
Ranch Hand Supply
/ MGM Eagle 2420 #3
I will add .... If I am correct ??? It it a Jinma 204.
Ronald
Ranch Hand Supply
/ MGM Eagle 2420 #4
Try googleing just MGM tractors -- place in Texas that sells Jinma and Foton -- either one of those look like the machine you are looking at?
regards
/ MGM Eagle 2420 #5
Can't say that I have, but the 2420 suggests it's a rebadged FarmPro 2420. Which is probably a little confusing to the new buyer, because a FarmPro 2420 is a rebadged JM200 (20hp/2wd).
My SWAG is that this MGM outfit gets this particular model from Homier/FarmPro, who got it in the first place from Jinma. MGM may just stick some "Eagle" decals where it would otherwise say FarmPro. Same tractor, different decals. Post the info that's stamped on the engine label - that may reveal you've actually only got 20hp.
//greg//
/ MGM Eagle 2420 #8
Yep, she is a Jinma 20 Hp 2 wheel drive tractor. May or may not have power steering so look at that if you plan on adding a loader. If no power steering you will need arms like Popeye's. That price seems a little high. They sell new for $4000 for the tractor and the implements can be had for under $1,500.
Do your research.
Chris
/ MGM Eagle 2420
Y'all figure the guy is pulling my leg about the 24 hp and power steering or he just doesn'r know any better?
/ MGM Eagle 2420 #10
Some did have power steering and some did not so it very well may. Many lie about the power of tractors or just plain got bad info and passed it on.
Chris
/ MGM Eagle 2420 #11
He may assume the number 24 in on the decal represents horsepower. The engine label will provide the definitive answer. If it says ~14.7KW, that makes it a 20hp tractor. But it's hard to not know the difference between power and manual steering. I enlarged the photos in that advert, and am pretty sure I see a priority valve in both - and a hydraulic steering cylinder in the lower photo
//greg//
2018 Johnston C201 Compact Street Sweeper (A61572)
2018 Johnston C201...
2017 Cadillac Federal 70IN Limo w 27466 Miles, Premium Federal Coachwork, Luxury Transport (A63689)
2017 Cadillac...
2005 Fontaine FTW5-8048SLW 48ft. 38 Ton T/A Piggyback Flatbed Trailer (A61573)
2005 Fontaine...
378908 (A61166)
378908 (A61166)
2021 Kubota SVL75-2 Track Loader (A63689)
2021 Kubota...
NEW HOLLAND C227 SKID STEER (A64279)
NEW HOLLAND C227...
