MF50
   / MF50 #1
wildebeast
conklin mi
massey ferguson 50
I have just bought a MF50 and I havent aquired a service manual yet but i am looking for a quick answer. This tractor doesnt have hydrauilics out the back and I would like to run a cylinder. Is there somwthing I can buy to make this happen rather easy? Thanks
   / MF50 #2
yes you can buy a valve which mounts on the stand pipe under the seat to run a rear remote. Mf50 is similar to a to-35,mf35,mf135 any of those could be a donor if they have the valve or buy one new for about 400 bucks
   / MF50 #3
You can also run a single acting cylinder off the 3-point control. There's a port (plugged with an allen head pipe plug) just below where the standpipe plate is located (plug is on the right side, just below hydraulic top cover) Run a single hose to rear, install quick connect, and use position control lever to run cylinder. You'll need to tie off 3-point draft arms so they don't move. (in "up" position)
   / MF50
Thank you very much it has been very helpful.
New/Unused CFG Industrial MX12RX Mini Excavator (A57453)
New/Unused CFG...
SD Launch SDLB25 (A53317)
SD Launch SDLB25...
(3) Goodyear G159 (A57454)
(3) Goodyear G159...
Snap On Timing Light (A57454)
Snap On Timing...
2025 GPS Trailers (A56859)
2025 GPS Trailers...
2019 PJ  40FT GOOSENECK TRAILER (A58214)
2019 PJ 40FT...
