MF50
wildebeast
conklin mi
massey ferguson 50
I have just bought a MF50 and I havent aquired a service manual yet but i am looking for a quick answer. This tractor doesnt have hydrauilics out the back and I would like to run a cylinder. Is there somwthing I can buy to make this happen rather easy? Thanks
yes you can buy a valve which mounts on the stand pipe under the seat to run a rear remote. Mf50 is similar to a to-35,mf35,mf135 any of those could be a donor if they have the valve or buy one new for about 400 bucks
You can also run a single acting cylinder off the 3-point control. There's a port (plugged with an allen head pipe plug) just below where the standpipe plate is located (plug is on the right side, just below hydraulic top cover) Run a single hose to rear, install quick connect, and use position control lever to run cylinder. You'll need to tie off 3-point draft arms so they don't move. (in "up" position)
2022 Mack Pinnacle T/A Day Cab Truck Tractor (A64556)
2022 Mack Pinnacle...
x (A68191)
x (A68191)
2013 WACKER NEUSON  TLN8 LIGHT PLANT (A68842)
2013 WACKER NEUSON...
2025 20in. Rotary Brush Cutter Mini Excavator Attachment (A66734)
2025 20in. Rotary...
2019 Peterbilt 520 T/A EZ-Pack 40Yd Front Loader Garbage Truck (A66736)
2019 Peterbilt 520...
CAT 320EL Hydraulic Thumb (A68134)
CAT 320EL...
