MF50
wildebeast
conklin mi
massey ferguson 50
I have just bought a MF50 and I havent aquired a service manual yet but i am looking for a quick answer. This tractor doesnt have hydrauilics out the back and I would like to run a cylinder. Is there somwthing I can buy to make this happen rather easy? Thanks
yes you can buy a valve which mounts on the stand pipe under the seat to run a rear remote. Mf50 is similar to a to-35,mf35,mf135 any of those could be a donor if they have the valve or buy one new for about 400 bucks
You can also run a single acting cylinder off the 3-point control. There's a port (plugged with an allen head pipe plug) just below where the standpipe plate is located (plug is on the right side, just below hydraulic top cover) Run a single hose to rear, install quick connect, and use position control lever to run cylinder. You'll need to tie off 3-point draft arms so they don't move. (in "up" position)
2019 Jeep Grand Cherokee SUV (A59231)
2019 Jeep Grand...
Bulk Lot of over 600 NEW Motorcycle Sprockets - 1980s to Present (A61307)
Bulk Lot of over...
JOHN DEERE 5065E TRACTOR (A59823)
JOHN DEERE 5065E...
2014 Ford F-250 Ext. Cab Service Truck (A59230)
2014 Ford F-250...
2019 Chevrolet Silverado 1500 LT 4x4 Crew Cab Pickup Truck (A59230)
2019 Chevrolet...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
