MF1526 mid mount mower ?
/ MF1526 mid mount mower ? #1
KMU
MF 1526
Hi..new to the forum and have upgraded my GC 2300 to a MF 1526 with a Woods 72” finish mower. I’m second guessing myself as the terrain I mow in certain areas is quite uneven and with Woods set as high as possible I am still hitting a scuffing the ground. How high are the blades of a Mid mount mower off the ground when raised to the highest position ?
/ MF1526 mid mount mower ? #2
Mid-mount mower options exist for a MF 1526, it has or can have a mid-PTO to drive one, etc. You'll have to chase that yourself if you conclude you want/need one. Before you get into that, I will try to clarify a couple of things to help. A finish mower is generally not equipped with anti-scalp rollers in the (left/right) middle of the deck. That is probably why you are seeing turf scalping when mowing over uneven/bumpy terrain with a finish mower. Most (all?) mid-mount mower decks that I have seen DO have middle of the deck rollers that lift the deck up over humps and uneven terrain. So in that context mid-mount mowers will "do better" in avoiding scalping.
However, if your land is so rough/lumpy/humpy/uneven that a Woods finish mower cannot be adjusted to a tall enough cut setting to avoid scalping... then you have issues that are not going to be solved by switching to a mid-mount mower or any other type for that matter. And adding a mid mount mower to your MF 1526 is going to hit you in the pocketbook for significant dollars. Good to learn more about the whole situation before you take the next leap.
RIDGID AIR COMPRESSOR (A65643)
RIDGID AIR...
ASSORTED STIHL POLE SAW PARTS (A62613)
ASSORTED STIHL...
FIFTH WHEEL ATTACHMENT PLATE (A65643)
FIFTH WHEEL...
2013 PETERBILT 367 MIDROOF SLEEPER (INOPERABLE) (A65643)
2013 PETERBILT 367...
iDrive TDS-2010H...
2018 Kia Forte Sedan (A61569)
2018 Kia Forte...
