MF 231 tire options
/ MF 231 tire options #1
nstractor
Would like to know if there is a wider front tire option that will fit my MF 231? The tractor has the stock 6.00-16 tires on it now but they tend to cut in around the wet stuff. Does anyone know if there is an option that will give me more float on this tractor? Thanks
/ MF 231 tire options #2
A lot of people run truck tires on the front of tractors, find a set of 6 or 8 ply wide and low profile tires. You may need to find wider rims with a deep offset but a Junk Yard could help there, I can't remember the bolt pattern of my massey.
/ MF 231 tire options #3
It ain't much, but a 6.5 inch tire will fit that rim. You may want to try a 4 rib tire instead of the factory 3 rib.
2008 DOOSAN G25 GENERATOR (A58216)
2008 DOOSAN G25...
1992 Norris Long Basket Trailer (A60460)
1992 Norris Long...
2016 Ford F-150 Crew Cab Pickup Truck (A59228)
2016 Ford F-150...
2000 Sterling L9513 Winch Truck (A63118)
2000 Sterling...
2025 48in. Farm Jack (A61567)
2025 48in. Farm...
CONEX BOX (A63569)
CONEX BOX (A63569)
