MF 231 tire options
/ MF 231 tire options #1
nstractor
Would like to know if there is a wider front tire option that will fit my MF 231? The tractor has the stock 6.00-16 tires on it now but they tend to cut in around the wet stuff. Does anyone know if there is an option that will give me more float on this tractor? Thanks
/ MF 231 tire options #2
A lot of people run truck tires on the front of tractors, find a set of 6 or 8 ply wide and low profile tires. You may need to find wider rims with a deep offset but a Junk Yard could help there, I can't remember the bolt pattern of my massey.
/ MF 231 tire options #3
It ain't much, but a 6.5 inch tire will fit that rim. You may want to try a 4 rib tire instead of the factory 3 rib.
KENWORTH CAB AND HOOD (A63569)
KENWORTH CAB AND...
2004 VOLVO VHD TRI/A CEMENT MIXER TRUCK (A59911)
2004 VOLVO VHD...
2009 Landoll 435A 50ft. 43 Ton T/A Tilt Deck Equipment Trailer (A60460)
2009 Landoll 435A...
2017 Ford Escape SUV (A61574)
2017 Ford Escape...
2021 JOHN DEERE 331G SKID STEER (A62129)
2021 JOHN DEERE...
2022 CATERPILLAR 299D3 SKID STEER (A62129)
2022 CATERPILLAR...
