MF 1045 Value
/ MF 1045 Value #1
mtnxtreme
Looking at a 1045 with loader 2200 hrs 4wd, how much is it worth and is it a good machine?
/ MF 1045 Value
Also does anyone know if you can put AG tires on this tractor, came with turfs
/ MF 1045 Value #3
mtnextreme Howdy, I'm sure you can put AGs on that tractor you will just need the right size in which a quick consult with a dealer should give the accurate sizes for that tractor (usually the current size but in AG)... ;)
Well as for the value: I went to iron search a saw one for 12,900 with canopy ,loader,ag's,garaged , condition 10 (best,like new) however it did not say how many hours? I tried to post the link but I'll have to learn all over again since the server upgrade...:confused:
/ MF 1045 Value #4
Mornin Mtnxtreme,
Here is a link to data on the MF 1045.TractorData.com - Massey Ferguson 1045
I own the MF 1040 FWD, have used it since Jan 04. I have 1455 hrs on it now. It had a MF 232 loader on it when I bought it. I payed $6000 and have not put a lot of money into it since purchasing. New front tires and fixed a few odss and ends. Changed all fluids and filters. I have ags all the way around. My engine is the same as thr one in the 1045. I believe my machine is a little heavier. I will include a pic of my tractor. Good luck.
/ MF 1045 Value
Hey Scotty, what size are your tires, have you had any trouble with parts, does the machine have good power.?
Thanks
/ MF 1045 Value #6
The MF 1040 is a brute ! I call it the beast :) Its got 8-16 ags on the front and 13.6- 24 on the rear. The tires are not loaded so I use a 35 gal drum filled with concrete and rocks off the 3pt for a counter weight. Its a geared machine with three speed ranges. I usually bush hog in mid range 4th gear about 3.5 mph. The 32 hp diesel has very good power and does about everything that I need to do on my property.
If your not that knowledgable about tractors I suggest you take a tractor person with you to check this machine out. They can spot things that you wouldnt normally see.
Feel free to ask anything and I will try and help!
Oh yes, parts can br pricey!
/ MF 1045 Value
Where are you getting the parts, directly from the Agco dealer or have you found an internet source, does this machine cross over to anything else, mostly everything does.
/ MF 1045 Value #8
Any parts that I have needed I have got them from local AGCO. You can also shop on EBay, lots of parts there also.
Kubota L295-DT Loader Tractor (A66285)
Kubota L295-DT...
John Deere Van Brunt 10' x 7' Grain Drill (A66285)
John Deere Van...
2017 FREIGHTLINER CASCADIA 6X2 T/A SLEEPER TRUCK TRACTOR (A59910)
2017 FREIGHTLINER...
Vermeer 605 Super F Round Baler (A65640)
Vermeer 605 Super...
1993 GMC Sierra Pickup Truck, VIN # 2GTEK19K7P1534489 (A65563)
1993 GMC Sierra...
2020 MACK GRANITE (A65643)
2020 MACK GRANITE...
