Metal Roof - Help
/ Metal Roof - Help #1
rvaitor
Platinum Member
Nashville, TN / Hickory, NC
Kioti DK55C
I am trying to find Metal Roof material from one of my buildings. Haven't had luck with local folks. This appears to be a stamped aluminum material.
Thanks
/ Metal Roof - Help #4
Not trying to be negative, but I've seen that material and if it was my problem I would replace it all if I had a problem. It's very flimsy, if it's what I've seen.
Try to find a metal roofing products dealer and price galvalume panels to replace the entire roof. You'll be much better off in the long run.
/ Metal Roof - Help #5
I agree, it may cost a few bucks but will be well worth it in the long run.
Farwell
/ Metal Roof - Help
I appreciate the advice. It is thin - been on the garage roof at least 25 years and the corn crib. I think the thinness may be an advantage - not sure. Hasn't rusted or needed paint still looks pretty good. Anyway, all but a small section has held up - wind blew it off. If I can't find some replacement panels I'll either go with asphalt or another metal product.
I am thinking maybe ALCOA made it.
/ Metal Roof - Help #7
I've seen that patern, but no idea where to get it.
Ick on asphault shingles, they don't last a darn on my out buildings. Good tin and you are good for the rest of your life. Bummer on the wind, we have had our share too this summer, lost 20 trees or so, but the buildings held up.
--->Paul
/ Metal Roof - Help #9
The others are right. It is very flimsy material (if it's what I think it is). I used it to cover a lawnmower shed that I threw up quickly. I think what I used came from underpinning on a mobile home. I had to piece it together to cover the 10'x10' shed. It was cheap (free) and keeps the mower dry. /forums/images/graemlins/smile.gif
Later,
BR
/ Metal Roof - Help #10
It's definately Alcoa. In 2002 I took down & reassembled a 50x120 barn and salvaged every inch of roofing. It was originally built in 1966. I used gasketed screws instead of the nails. The biggest problem with aluminun roofing is tearing when the fasteners get loose.
/ Metal Roof - Help #11
/ Metal Roof - Help #12
I'm new to posting here. I included the Alcoa website product page here but it didn't post. Just search for "Thrifty Rib" on the Alcoa dot com page.
/ Metal Roof - Help
Thanks Guys,
That was just a guess on my part, but that is definately the pattern - hopefully they still make the rib spacing etc. Seems one of the advantages is you just wrap this stuff around the facias - so no seams.
Again THANKS! - now I just need to find someone in NC that sells it.
2025 Kubota L3902HST w/ Kubota LA526 loader - 1 hour and new financing
2025 Kubota...
2012 BMW 328i Coupe (A61569)
2012 BMW 328i...
2018 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
2014 Ford Transit Connect Van (A61573)
2014 Ford Transit...
Stout Brush Grapple 66-9 (A66285)
Stout Brush...
2014 Chevrolet Traverse (A62613)
2014 Chevrolet...
