Mechanical shuttle transmission
/ Mechanical shuttle transmission #1
dknarnd
Columbia County, PA
JD1010, JD B, TC40A (new)
Looking at the L4400 tractor which has the gear drive transmission which includes a mechanical shuttle shift in the low and reverse ranges. Can anyone tell me how this transmission works when in low shifting between forward and reverse? Do you use the clutch? Can you use it at any RPM?
/ Mechanical shuttle transmission #2
just got my new 4400..the shuttle is a big and nice change from the old system...you have to clutch ...but just move the lever forward to go forward back to go backward...the shift lever stays in what ever gear you select..neat system....
/ Mechanical shuttle transmission #3
you still have to stop before changing directions but system is very easy to use and efficient. the syncronized shuttle is better, but hey, so far this tractor has been oustanding.
tim
2013 KENWORTH T370 DUMP TRUCK (A64280)
2013 KENWORTH T370...
Wolverine TL-12-72W 72" Skid Steer Tiller (A62679)
Wolverine...
Toro Reelmaster 4000 D Mower (A65579)
Toro Reelmaster...
1989 Freightliner FC60 Day Cab Truck, VIN # 1FUP2DYBXKH356541 (A65563)
1989 Freightliner...
2001 Ford F-450 Service Truck, VIN # 1FDXW47F61ED87989 (A65563)
2001 Ford F-450...
Wilbeck 2109 12ft. Digger Disc Chisel (A65640)
Wilbeck 2109 12ft...
