LD1
Epic Contributor
Just wanting to hear what others thoughts and opinions are.
Current truck is a 2005 Dodge 3500 DRW with 99k miles.
Low miles but age/time is killing this truck. Getting to the point I am lacking confidence in it's reliability to get me, tractor, and trailer to and from my jobs.
I have had this truck 9 or 10 years now and only racked up about 35k of the miles myself. This tricks sole purpose is to tow tractor around, tow dump trailer selling wood, and plowing snow in the winter. So I need it to be reliable. And if I keep it any longer, I think I need to invest alot of time and money getting to that point.
Last year I replaced the expensive fan clutch. Most highway drivers would probably never know this is bad...but plowing snow....slower speed...no airflow....truck gets hot.
Now that clutch, or wiring going to and from, has a problem. Truck isn't overheating....but pulling a constant 1.5a draw on the battery. I just pulled the fuse and put it back in when I need truck. Probably not a hard fix....but a harness with 8-10 wires....and trying to get a diagram or pinout on modern stuff is like pulling teeth.
Also getting a trouble code for turbo overboost. All accounts online seem to indicate MAP sensor or IAC. Truck still runs fine though.
Last year when plowing, started to get a slip in second gear. Adjusted the front band back to spec...problem solved but I think that is gonna be the last time that fix works...as I am pretty much out of adjustment there.
So I am thinking the trans is gonna need an overhaul in a year or two anyway. 35k hard miles of towig and plowing on a stock trans. Needed a good shift kit from the start, but no shop I can find wants to do a kit on an aged trans. They all say just wait til it needs rebuilt.
But all that isn't the big issue.....the corrosion of so many vital lines under the truck. Was out and about Friday and at my last job I noticed ATF undercoating the whole truck. But couldn't pinpoint the leak. The power steering has been leaking...but I just keep it topped up with ATF. So thinking it finally blew the seals. Went home with the intent of replacing the PS gearbox....but that wanst it. Transmission cooling lines.
They were so bad I am surprised it was just a pinhole. Lines were crazy expensive, one was on a 60 day backorder. Just had hydraulic hoses made up and back in business, but while in there working....must have bumped the fuel supply line....and the last spec of rust holding it together let go. Spraying fuel. Its a nylon tube but the last 4" it transitions to steel via quick connect and to banjo bolt fitting. Had to cut the QC off and just shive the nylon over the steel stub at the banjo.
So now the truck is functional again, but who knows what might let loose next pothole. The steel parts of the coolant lines running to the trans cooler that's on the block....badly corroded. Turbo oil cooler line....badly corroded. The rest of the low pressure fuel lines from filter to injector pump, and return, and from regulator off common rail....three in total I think....look like they won't make it til winter.
3 weeks ago truck started to get hot. Parked it and seen coolant seeping out around lower radiator hose connection. Top up with water, limp the last 5 miles home, and went to take that spring clamp off to see why it was leaking, and it just snapped in half. Rusted through on the top.
Oh, and about 6 months ago I had to replace the oil pan as it was rusted through and seeping oil. Glad I caught that one before it turned into more than a seep.
So at the very least if I keep truck, it's gonna need probably a grand worth of hoses, tubing, etc to replace all the corroded stuff. It's gonna need a PS gearbox to eliminate that leak. Then I'd say a trans rebuild within a year. Then figuring out the MAF/MAP/IAC code, and the fan clutch that is draining the battery.
Everyone keeps telling me trucks are worth a pretty penny because pre-emissios crack down. 24v 5.9 common rail. Weather it be soon....or down the road a ways....I am thinking that my next truck with have an emphasis on newer rather than low miles. Because age is what kills vehicles anymore....not use/miles. I think I'd rather have a 3-4 year old 180k mile truck as opposed to a 8-10 year old truck with only 80k. (And they are actually similar in price.)
But going to a 3-4 year old truck is a game changer for me. I havent follows what has happened recently. Do know crap about def, what to look out for, what to avoid, etc.
Am I foolish for considering an upgrade about 10 years newer than what I have? Or should I fix and keep what I got because the 5.9 and no emissions is that good?
