Max tow weight confusion
   / Max tow weight confusion
one other thing I would consider buying a gooseneck vs bumper pull, do you know anyone else with a goose hitch? If your truck were broke down and you had to get the trailer from point a to b, could you? Granted most towing companies can figure it out, they are getting very pricey also.
Several farmers in the family. No shortage of gooseneck trucks.
  • Good Post
Reactions: D&D
   / Max tow weight confusion #22
My hitch is the same. I would go 12k if I could find one. Something else I was wondering. Ford rates their hitch at 12.5 k max WD. Does that hold true even with a higher rated hitch due to the leverage, etc.?
My 373 rear is rated at 12k with weight distribution hitch.
If you are referring to removing the factory hitch and installing a heavier duty hitch, I would have no idea.
FYI, installing a weight distributing hitch is very easy with a few measurements and adjustments to the ball mount. The truck side equipment remains factory. It also makes even moderate loads tow much smoother imho.
I’ve located a couple of goosenecks I’m going to check out.
5' MOWER (A52706)
5' MOWER (A52706)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
CATERPILLAR 627K SCRAPER (A52707)
CATERPILLAR 627K...
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A59575)
2018 FREIGHTLINER...
2015 JOHN DEERE 35G EXCAVATOR (A52707)
2015 JOHN DEERE...
1998 REINKE TRAILER HEAVY HAUL TRAILER (A58214)
1998 REINKE...
