Max tow weight confusion
/ Max tow weight confusion
one other thing I would consider buying a gooseneck vs bumper pull, do you know anyone else with a goose hitch? If your truck were broke down and you had to get the trailer from point a to b, could you? Granted most towing companies can figure it out, they are getting very pricey also.
Several farmers in the family. No shortage of gooseneck trucks.
  • Good Post
Reactions: D&D
/ Max tow weight confusion #22
My hitch is the same. I would go 12k if I could find one. Something else I was wondering. Ford rates their hitch at 12.5 k max WD. Does that hold true even with a higher rated hitch due to the leverage, etc.?
My 373 rear is rated at 12k with weight distribution hitch.
If you are referring to removing the factory hitch and installing a heavier duty hitch, I would have no idea.
FYI, installing a weight distributing hitch is very easy with a few measurements and adjustments to the ball mount. The truck side equipment remains factory. It also makes even moderate loads tow much smoother imho.
I’ve located a couple of goosenecks I’m going to check out.
Kubota U55-4 (A57148)
UNUSED RAYTREE RMBD50-50" HYD DRUM MULCHER (A60432)
UNUSED RAYTREE...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
TANK MANIFOLD (A55745)
2019 CUSHMAN HAULER PRO ELECTRIC GOLF CART (A58375)
2019 CUSHMAN...
2021 JOHN DEERE 650K LGP CRAWLER DOZER (A60429)
2021 JOHN DEERE...
