Max 26 XL electrical / glow plug controller issue
/ Max 26 XL electrical / glow plug controller issue #1
Cramby
Galesburg MI
Mahindra Max 26XL TLBMMM
My tractor has started giving me trouble after 8 yrs of no problems. The glow plug controller buzzes, dash go dim, then go out, results in a no start. Disconnect battery and re- connect, power comes back and starts, most of the time. Anyone else has these symptoms?
/ Max 26 XL electrical / glow plug controller issue #2
Could be many things, but sounds like a bad connection at the frame ground or battery post. Clean all those good and see if it continues.
Will do.
/ Max 26 XL electrical / glow plug controller issue #4
sounds more like a connection issue. I pretty sure that the controller and the dash lights are on 2 totally different circuits. I would check all connections carefully & closely including the power wire that feeds the fuses
Thank you will check all and report back.
I installed a battery disconnect a few years ago. I found it's internal switch failed. Problem solved.
/ Max 26 XL electrical / glow plug controller issue #7
I would start buy checking wires to the ignition switch and the switch itself or a pinched wire going to the glow plugs.
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A61567)
2016 Ford F-150...
2014 Chevrolet Tahoe SUV (A64194)
2014 Chevrolet...
2023 SANY SY225C EXCAVATOR (A63276)
2023 SANY SY225C...
2012 PETERBILT 386 (A65643)
2012 PETERBILT 386...
1999 MACK MIXER (A65643)
1999 MACK MIXER...
1968 MTTI Car Hauler Trailer Trailer (A62613)
1968 MTTI Car...
