Max 26 XL electrical / glow plug controller issue
/ Max 26 XL electrical / glow plug controller issue #1
Cramby
Galesburg MI
Mahindra Max 26XL TLBMMM
My tractor has started giving me trouble after 8 yrs of no problems. The glow plug controller buzzes, dash go dim, then go out, results in a no start. Disconnect battery and re- connect, power comes back and starts, most of the time. Anyone else has these symptoms?
/ Max 26 XL electrical / glow plug controller issue #2
Could be many things, but sounds like a bad connection at the frame ground or battery post. Clean all those good and see if it continues.
Will do.
/ Max 26 XL electrical / glow plug controller issue #4
sounds more like a connection issue. I pretty sure that the controller and the dash lights are on 2 totally different circuits. I would check all connections carefully & closely including the power wire that feeds the fuses
Thank you will check all and report back.
I installed a battery disconnect a few years ago. I found it's internal switch failed. Problem solved.
/ Max 26 XL electrical / glow plug controller issue #7
I would start buy checking wires to the ignition switch and the switch itself or a pinched wire going to the glow plugs.
2012 KENWORTH T800 SLEEPER (A63569)
2012 KENWORTH T800...
2006 Ford F-350 4x4 Crew Cab Pickup Truck (A61573)
2006 Ford F-350...
2014 Cadillac ATS Sedan (A59231)
2014 Cadillac ATS...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2018 Ford F-150...
(APPROX. 5) 28' - 29GA BLK TIN (A63290)
(APPROX. 5) 28' -...
2015 WESTERN STAR 4900 GLIDER TANDEM AXLE DAY CAB (A59575)
2015 WESTERN STAR...
