Match tedder to drum mower
/ Match tedder to drum mower #1
kballein
Mount Orab, Ohio
John Deere 5303
Hi,
I have a Zetor 185 (6 ft) drum mower and am in need of a new tedder. I am looking at a Galfre GTS280. My question is will it ted two windrows left by the drum mower which should be 6 feet apart with the windrows straddling each 6 ft space between windrows. I just don't know how wide the windrows themselves typically are. It's really too wet here or I would just hook it up and test it.
The specs on the tedder say 9' 3" working width, but I think that includes the guards. The transport width is 8'3" which is probably the actual width of hay it would pick up.
Thanks,
Ken
/ Match tedder to drum mower #2
I'm going to say yes, use a 2 rotor tedder here (8' 6")and it will do two swathes from a 5 disk mower (6' 9")
Swathes lay flat and you can get it all if you drive just right. If you get off course you will miss some on the edges.
If you are putting out a windrow dead center with your mower probably will do it easy.
2005 Peterbilt 387 with Wet Kit (A63118)
2005 Peterbilt 387...
2014 CATERPILLAR 573C FELLER BUNCHER (A64276)
2014 CATERPILLAR...
New/Unused landhonor 5 Gallon Vacuum Cleaner (A65583)
New/Unused...
set of 4 tractor trailer tires Roadforce (A63689)
set of 4 tractor...
ELECTRIC MOTORS, ELECTRIC PUMP (A64276)
ELECTRIC MOTORS...
Front Tank Bracket (A64127)
Front Tank Bracket...
